LilBeaver Posted February 6, 2010 #51 Posted February 6, 2010 The tachs arrived at my house today, Saturday, February 6th. Will ship to members that ordered by Monday February 8th. Gary
Bloodbought1 Posted February 8, 2010 #54 Posted February 8, 2010 Thanks for the update... Guess what it's snowing here!!!!!!
jonesy Posted February 11, 2010 #56 Posted February 11, 2010 got mine, waiting for warmer weather to test it.
Snaggletooth Posted February 11, 2010 #57 Posted February 11, 2010 Mine arrived today. Thanks again. Mike
LilBeaver Posted February 12, 2010 #59 Posted February 12, 2010 I think I'm just a total D.A. What is the trick to turning this thing off? Also, It seems that I had to set the Tachometer to the "02" option, which the instruction claims to be the setting for "one fire per revolution" - which I thought I had remembered these things fire twice per revolution. Is this what others had to do too?
dingy Posted February 12, 2010 Author #61 Posted February 12, 2010 I think I'm just a total D.A. What is the trick to turning this thing off? Also, It seems that I had to set the Tachometer to the "02" option, which the instruction claims to be the setting for "one fire per revolution" - which I thought I had remembered these things fire twice per revolution. Is this what others had to do too? I contacted to supplier of tachs and he said there is no way to turn tach off. The battery is supposed to be good for 35,000 hours, which is about 4 years. Gary
LilBeaver Posted February 12, 2010 #62 Posted February 12, 2010 I contacted to supplier of tachs and he said there is no way to turn tach off. The battery is supposed to be good for 35,000 hours, which is about 4 years. Gary Gotcha. Thanks a lot
MiCarl Posted February 12, 2010 #64 Posted February 12, 2010 Used mine today to set my mixtures. Worked like a champ!
Riderduke Posted February 13, 2010 #66 Posted February 13, 2010 i got mine today ! :thumbsup: Me Too!
Bloodbought1 Posted February 13, 2010 #67 Posted February 13, 2010 i got mine today ! :thumbsup: Me too !!!!!
BigBoyinMS Posted February 13, 2010 #69 Posted February 13, 2010 Mine was in the mailbox this morning... when I finally found it under the snow!
dingy Posted February 15, 2010 Author #71 Posted February 15, 2010 I contacted to supplier of tachs and he said there is no way to turn tach off. The battery is supposed to be good for 35,000 hours, which is about 4 years. Gary The supplier emailed me with the way to turn off the tach. He contacted the manufacturer to get this. When you do this, all information is lost that has been stored. In our case, it probably does not matter as it is being used as a tool. The meter will have to be reset each time it is to be used. It is somewhat lengthy, but here it is. Press and hold down S1 button, will show 01-05 (do not release S1 at this time), when display 05, release S1. After 8-10 seconds(at this time, the meter will flash), the meter will return to total hours, will display 0.0 hours (the meter will not flash). Then press and hold down S1 and S2 buttons, the meter will display 01-09 (don't release S1 and S2 buttons), after showing 00000, release S1 and S2 buttons, the meter will show 00000 to 99999, then return to 0.0. Now the meter is reset, after 5 seconds or so, the meter will become blank display, 0.0 will disappear. Gary
aharbi Posted February 16, 2010 #72 Posted February 16, 2010 Yep, that worked, meter now off. thanks Gary
sleepy2 Posted February 23, 2010 #73 Posted February 23, 2010 Hey dingy was wondering if you have a tracking number to see how much longer till the tach's get here?
dingy Posted February 23, 2010 Author #74 Posted February 23, 2010 I do not have any tracking numbers outside US. Islandmech got his yesterday, he is in Victoria B.C. Canada. Gary
sleepy2 Posted February 23, 2010 #75 Posted February 23, 2010 No problem will just have to keep checking mailbox. Thanks again!
