vic venture Posted January 12, 2010 #1 Posted January 12, 2010 My choke cable broke or came loose at the handlebar. I got another cable and I'm about to dive in. Does anyone have any hints that the manual won't tell me? I also noticed a small coolant leak from somewhere near the top of the engine when it is parked. At least now it is warm enough to get in the shop and do it!
Fvogt Posted January 12, 2010 #2 Posted January 12, 2010 The way I do it is to duct tape the new one to the old one and pull it through. In this way you have the cable in the same place as the original. It is not a hard fix, I attach the top end first. . Fred
Chaharly Posted January 12, 2010 #3 Posted January 12, 2010 About your antifreeze leak I have that too on my 85, nothing to be alarmed with, its probably just a loose hose clamp my bike started leaking when it got below 50 too so i don't think its too big of a deal!
Fvogt Posted January 12, 2010 #4 Posted January 12, 2010 Ops forgot about that, it's a common problem and I find that if clean or replace the O-ring on the Thermostat bypass it goes away. Fred
vic venture Posted January 12, 2010 Author #5 Posted January 12, 2010 So I should tighten my clamps and replace the Bypass o-ring. Gotcha. I had a leak from the carb when parked but seafoam seemed to help that...THANKS FOR THE CARB THREAD....I dreaded taking those off. Thanks for the info guys. I knew it was a good idea to ask.
vic venture Posted January 25, 2010 Author #6 Posted January 25, 2010 The way I do it is to duct tape the new one to the old one and pull it through. In this way you have the cable in the same place as the original. It is not a hard fix, I attach the top end first. . Fred I tried this like you suggested and had it done in 15 min. It would have been quicker but I did not pay close attention when I took the switch apart that the choke lever mounted to. Thanks Man, I would have done it the hard way without your wisdom!
dingy Posted January 25, 2010 #7 Posted January 25, 2010 So I should tighten my clamps and replace the Bypass o-ring. http://www.venturerider.org/classifieds/showproduct.php/product/1724/cat/6 Here is an add in classified section that Skydoc 17 has a kit to fix dripping bypass valve. Gary
