Sheradan Posted January 11, 2010 Share #1 Posted January 11, 2010 I was wondering if somebody had one and do you like it? Also, does the vent cut down passenger buffeting and does rain come through when it's closed? Link to comment Share on other sites More sharing options...
utadventure Posted January 11, 2010 Share #2 Posted January 11, 2010 I have an extra large Clearview shield with the vent and love it!! It doesn't stop passenger buffeting as much as it does for the rider. I haven't ridden in much rain but didn't have any leakage during mild to medium rain. It's an excellent windshield purchase. Dave Link to comment Share on other sites More sharing options...
Cougar Posted January 11, 2010 Share #3 Posted January 11, 2010 Link to comment Share on other sites More sharing options...
Owen Posted January 11, 2010 Share #4 Posted January 11, 2010 I have a shorter clearvue with vent. I love it. When raining, it may allow a few drops through but won't matter much. Link to comment Share on other sites More sharing options...
friesman Posted January 12, 2010 Share #5 Posted January 12, 2010 I love my clearview with the vent. i bout the xxl tinted and i found it really stopped the buffeting and it helped Deb a bit on the back. Its surpising how much the vent helps cool you on a hot day and it also helps with buffetting if you open it a crack. Ive ridden thru a couple of heavy rain days and havnt noticed any major leakage, but it is hard to tell when youre outside in the rain, ... I find i dont get quite as wet with the wider xxl windshield Brian Link to comment Share on other sites More sharing options...
starkruzen Posted January 12, 2010 Share #6 Posted January 12, 2010 I got one a couple of weeks ago, or maybe months, anyway I think it is an excellent product. I got mine a couple of inches smaller than stock, should of got it smaller. It comes with lowers and it is just the sheild only. It was farely easy to install. It fitted perfect. The vent is well worth it especially in summer heat..the vent allows air to flow and get you cooler. I would recommend it. I have it installed on my 07 RSTD. I have posted picture here some time ago. Mark Link to comment Share on other sites More sharing options...
Blue Giant Posted January 12, 2010 Share #7 Posted January 12, 2010 Is wind buffeting a common problem with first gen's? I find it bad on mine and it has the windshield deflectors on the side to effectively widen the windshield the buffeting drives me crazy! My XJ1100 with a windjammer was great! Link to comment Share on other sites More sharing options...
Naked Rider Posted January 12, 2010 Share #8 Posted January 12, 2010 i like the clearview with the vent but there is one problem with it bugs. you have got to watch the way you have the vent if not you will get a taste of every bug that past through the vent and make sure you wear glasses if you have found a way around this please share it with me the big green one are a little bitter. Link to comment Share on other sites More sharing options...
YamaDuck Posted January 12, 2010 Share #9 Posted January 12, 2010 I guess I'll be the sour apple. Although I like the Clearview and the vent I have had a few issues with both. I have the XXL Clearview. The vent does leak when it rains. Nothing major but water does come through. The two screw (bolts) whatever you want to call them vibrate loose so you need to keep check on them. Most of the water problem I have is with water being pushed up and over the windshield and as you know with the Venture the wind comes up from behind you so it pushes whatever water comes over the top up against the inside of the windshield. As for the vent it is nice most of the time but I was out west last year during the record breaking heat wave and when your doing 65 to 85 mph in 106 to 112 degree weather with the vent open it was like somesone had a blow dryer blowing hot air in your face. I close my vent and was a lot more comfortable. For the most part though I like it. Link to comment Share on other sites More sharing options...
warthogcrewchief Posted January 12, 2010 Share #10 Posted January 12, 2010 I guess I'll be the sour apple. Although I like the Clearview and the vent I have had a few issues with both. I have the XXL Clearview. The vent does leak when it rains. Nothing major but water does come through. The two screw (bolts) whatever you want to call them vibrate loose so you need to keep check on them. Most of the water problem I have is with water being pushed up and over the windshield and as you know with the Venture the wind comes up from behind you so it pushes whatever water comes over the top up against the inside of the windshield. As for the vent it is nice most of the time but I was out west last year during the record breaking heat wave and when your doing 65 to 85 mph in 106 to 112 degree weather with the vent open it was like somesone had a blow dryer blowing hot air in your face. I close my vent and was a lot more comfortable. For the most part though I like it. A trick I learned in the maintenance world is to use RTV to keep a screw or bolt from backing out. Since its on a windshield, put a dab of clear RTV on the threads of your hardware and screw it in. Problem solved! Link to comment Share on other sites More sharing options...
dynodon Posted January 12, 2010 Share #11 Posted January 12, 2010 I don't have the clearview with vent, but was considering it, will still consider clearview, but not the vent. Talked to too many people with it that say it lets the bugs right through, and like many have said here, lets some water through even when closed. I find the air flow from around the forks to be plenty to keep me cool in hot weather. As for the buffeting, check how tall your shield is now, and maybe you need one taller or maybe shorter. My Gen I had some buffeting that wasn't bad but a different helmet calmed almost all of it, no other change! go figure. Carefully, while riding, feel with one hand to try to figure out where the air is coming from, and remember strong side winds will cause problems no matter how good your other protection is. Link to comment Share on other sites More sharing options...
friesman Posted January 12, 2010 Share #12 Posted January 12, 2010 Is wind buffeting a common problem with first gen's? I find it bad on mine and it has the windshield deflectors on the side to effectively widen the windshield the buffeting drives me crazy! My XJ1100 with a windjammer was great! I found my 85 bad for buffetting with the slip stream windshield, but the xxl clearview is 2-3 inches wider and taller and the buffetting is way less for me. The XXl actually goes past the mirrors to protect you pretty effectively on the g1 ventures. Brian Link to comment Share on other sites More sharing options...
YamaDuck Posted January 12, 2010 Share #13 Posted January 12, 2010 A trick I learned in the maintenance world is to use RTV to keep a screw or bolt from backing out. Since its on a windshield, put a dab of clear RTV on the threads of your hardware and screw it in. Problem solved! Thanks for the tip but what is RTV? I would like to get some. Link to comment Share on other sites More sharing options...
warthogcrewchief Posted January 13, 2010 Share #14 Posted January 13, 2010 RTV can be purchased at ANY auto parts store or hardware store. RTV stands for "Room Temperature Vulcanization". You should be able to find that a tube will cost around $5 and will have MANY uses! Ace Hardware Lowe's Home Depot Off Topic (just a bit) - Often times, RTV is used to seal gaskets, or even make a new gasket. Be wary though, some gaskets are NOT supposed to have any RTV on them. Link to comment Share on other sites More sharing options...
raceman62race Posted January 13, 2010 Share #15 Posted January 13, 2010 If you don't want to spend the money for the complete windshield all you have to do is buy a windshield vent for a Goldwing and install it on the stock windshield. You can get them off E-bay for around $40.00. That's all Clearview does is install Goldwing vents on their windshields Link to comment Share on other sites More sharing options...
YamaDuck Posted January 13, 2010 Share #16 Posted January 13, 2010 RTV can be purchased at ANY auto parts store or hardware store. RTV stands for "Room Temperature Vulcanization". You should be able to find that a tube will cost around $5 and will have MANY uses! Ace Hardware Lowe's Home Depot Off Topic (just a bit) - Often times, RTV is used to seal gaskets, or even make a new gasket. Be wary though, some gaskets are NOT supposed to have any RTV on them. Thanks for the tip! Link to comment Share on other sites More sharing options...
a1bummer Posted January 15, 2010 Share #17 Posted January 15, 2010 i like the clearview with the vent but there is one problem with it bugs. you have got to watch the way you have the vent if not you will get a taste of every bug that past through the vent and make sure you wear glasses if you have found a way around this please share it with me the big green one are a little bitter. My vent windows on my old Ford can have the same affect when I turn them all the way around as far as they would go. Except it's the passenger who gets nailed with the bugs. Especially during junebug season. I do it to my brother now and then. It was funny till he figured out what I was doing! Link to comment Share on other sites More sharing options...
