hipshot Posted October 2, 2007 #1 Posted October 2, 2007 i decided to "lower" the front end on my '86, yesterday!!!!! WRONG!!!!!!! cannot be done!now i have the rest of today, to re-install all of the parts that i had to remove, to find this out! just jt
Redneck Posted October 2, 2007 #2 Posted October 2, 2007 Thats what you call paying for an education. The mexican influence is starting to show in you. Wanting to make a low rider out of an antique scooter I just don't know about you and no the tires and wheel off a 10 speed won't fit ether.:rotf:
Thom Posted October 2, 2007 #3 Posted October 2, 2007 ok jt are you goin to tell us why , :detective:
hipshot Posted October 2, 2007 Author #4 Posted October 2, 2007 Thats what you call paying for an education. The mexican influence is starting to show in you. Wanting to make a low rider out of an antique scooter I just don't know about you and no the tires and wheel off a 10 speed won't fit ether.:rotf: mike you are still "as full of s#!T as a tomcat"! lol just jt
hipshot Posted October 2, 2007 Author #5 Posted October 2, 2007 ok jt are you goin to tell us why , :detective: well THOM, since you asked - - - - - the "CLASS" ,air valve is directly below the tree, on both forks. it is apparently "pressed on", and then , the air line and bleeder line, are tapped and threaded, into the fork. without changing over to 2nd gen cheapy forks, you cannot alter the height of your first gen, front end. soooo, now i'll go with the "10 speed" smaller front avon tire! lol just jt
bikenut Posted October 2, 2007 #6 Posted October 2, 2007 Yes you can lower the front end on 86 thru 93 ventures. You can lower it a little by removing the plastic spacer inside of the forks on top of the spring inside the fork tubes. I just made mine higher by making the spacer bigger to get my trike to ride level. Give it a try and see what it will do for you. Later Bikenut
hipshot Posted October 2, 2007 Author #7 Posted October 2, 2007 i stand corrected! i don't think the small "drop" achieved by removing the plastic spacer, would equate into much of a difference ,in slow speed handling. i might just try it though. thanks bikernut! just jt
GigaWhiskey Posted October 2, 2007 #8 Posted October 2, 2007 JT is the one person i know that can fix something, that may or may not be broke for less than a dollar! lol I still remember the diaphram fix.
Dano Posted October 2, 2007 #9 Posted October 2, 2007 I looked at dropping mine, too, but as soon as I saw those air rings, I decided-----I've had my butt kicked by myself way too many times to try that, so I just put it back together. But I might try that spacer thing. I'm like hipshot, just a little better on the slow side ( of course, 1st genners don't always see speeds that low, unless we're pulling into the garage to park it for the night!) Dan
hipshot Posted October 3, 2007 Author #10 Posted October 3, 2007 JT is the one person i know that can fix something, that may or may not be broke for less than a dollar! lol I still remember the diaphram fix. actually, bud, this one went WAY over budget!!! cost me $1.80, for hardware to make a tool to recompress front forks, back up into the triple tree!!!!!! i pulled the steering head bearing, NO GREASE!!!! just some faint semblance of a brownish , waxy , looking film! washed it out , repacked the bearing, better than brand new! just jt
Cutty Posted October 3, 2007 #11 Posted October 3, 2007 Check with Race-Tech, i think they sell lowering front end kit for 1st gens. lowers 1' to 1.5'.
Guest Popeye Posted October 3, 2007 #12 Posted October 3, 2007 Oh Yeah, I got it figured now. [ATTACH]12617[/ATTACH]
