Has anyone put Vmax wheels and tires on their VR?
Is there any potential problems?
Inquiring minds want to know . . . Thanks!
  GeorgeS said:
If you are talking about a 1st gen, you can't go with Wider Tires, there is no clearance with the drive shaft for a wider tire.
The Vmax engine and trans can be installed in the VR.
The differential can be installed in the VR.
You're saying the Vmax has something different in the rear wheel assembly?
It's got a wider swing arm and rear wheel?
I've seen on other (other than VRs) bikes where people have cut a chunk out of the drive shaft portion of a swing arm to allow access for a wider tire...then welded a plate where the chunk was cut out...
I'm not saying it's a good idea. I wouldn't do it, but it's always an option. :hihi:
Why wouldn't the V-Max drive shaft/swing arm fit into a VR frame?
Don't know about the fit, but the V-Max rear wheel is a 15" compared to the 1stGen at 16". Might present a problem with the speedometer readings.
Since the First Gen. speedo is driven off of the front wheel, the speedo will be the same no matter what tire/rim you put on the back of the bike. Now, that would change if you put a different tire/rim on the front.
Just so we are all on the same page, :thumbsup2:
Earl
OK, I have done a little research in the VR and Vmax manuals.
I then calculated the tire dimensions.
It would seem that putting a Vmax rear tire on a VR would increase the tire width by about 1/2" (1/4" per side). My 1985 VR has about 1/2" of clearance between the driveshaft and the edge of the rear tire.
The VR rear tire height appears to be 25.92" versus the Vmax at 25.64". This translates to making the VR only 0.14" closer to the ground.
The wildcard here will be the tire manufacturers seem to have slightly different dimensions for the same size. However, this makes me think if I come across a good deal on Vmax wheels/tires, I might pick them up!
1985 VR Tires
front = 120/90-18-65H
120mm or 4.50/4.75" wide
108mm or 4.25" sidewall
rear = 140/90-16-71H
140mm or 5.50/6.00" wide
126mm or 4.96" sidewall
Vmax Tires
front = 110/90V-18
110mm or 4.00/4.75" wide
99mm or 3.90" sidewall
rear = 150/90V-15
150mm or 6.00/6.25" wide
135mm or 5.32" sidewall
Earl
Dang, I knew that.... :bang head: If the tire fits you must acquit... Maybe running a 15" wheel would be better than swapping out the final?? And there's one on Ebay right now
  Sheradan said:
OK, I'll ask, what's the point?
Many folks customize their scoots with fancy paint and chrome stuff. Many others cannot understand why one would change anything.
I want my VR to run better - faster - quicker and look a certain way without getting too far away from the stock handling and ride. The Vmax rear tire is wider and looks more aggressive, and darn few VR's are running around wearing Vmax wheels. :happy34:
