Does any know where I can find some instructions for installing passing lights on my 07 RSTD? The instruction that came with it is a bit vague at best! I have been search strings here but have not found anything useful.
Any assistance would be greatly apprciated!
Thanks
Mark:nanner:
  wes0778 said:
:no-no-no: It's to early for April Fools jokes!!!:stickpoke:
How hard/easy is it to do? I could do the nuts and bolts, it's the electrical I'm worried about.
Ben
Ben
The Electrical is not that big a deal. You will have to split the fairing and may have to pull the tank to run a main power wire from the battery. Just my preference, but I like to put the a main power fuse as close to the battery as possible, so the hot wire running under the tank is fuse protected.
[ame=http://www.venturerider.org/forum/showthread.php?t=525]Standard Passing Light Relay Wiring - VentureRider.Org[/ame]
http://venturerider.org/forum/showthread.php?t=26385&highlight=Passing+Light+Wiring
There are a number of others on this subject, just do a search on the Tech Section.
  starkruzen said:
It was easy! Took about a hour and half.
You can do it. The wiring was the easy part.
:12101:
Looks Like he has a RSV, so a little more involved...
My dad is coming to town today and he said he would look at it and try. He's a little more mechanical than me. If not, I'll support the Yamaha dealer. They seem like a good group of guys.
Ben
Ben
gamecock,
if the yammy dealer does the install, ask them to use a 30 or 40 amp relay (which does not come with the lamp kit). i just did the install on my 07 RSTD and the only issue i had was making the oem flashers fit onto the provided shaft - but got some great advice from this forum and that issue was resolved. good luck & you will absolutely love the look.
Okay I got the passing lights mounted that Santa brought me as well, my hard part was getting the lights to line up, I guess I won't know if I aimed them right untill it's warm and dry enough to test on a ride. Anybody else have trouble aiming?:confused24:
Ben
By the sounds of it if you support the stealer they will not use a relay to control them and you will be looking at replacing your ignition switch down the road. Just passin on some of the things I read here. :thumbsup:
Anyone have a link for the 30 or 40 amp relay that was mentioned above. I think I found someone (a buddy) who will do it, I just need to gather all the needed parts. Thanks
Ben
its a 5 pin Bosh type relay , your local auto parts store will have them , look in the fog lite section . its the same relay used when installing fog lites .
NAPA (Echlin) # AR274
The neat thing about this relay is it has 2 #87 terminals, one for each driving light so no "Y" connector needed.
Got one in case my RSV is running the passing lights through the ignition switch. Now for the exploratory surgery...
