OK....I am getting ready to swap my two antennas out.
I went out there and got ready to swap them out (should be easy right)...and now I see 3 wrench points (flat spots)...
I tried very lightly to turn all 3, but I am afraid I might damage the antenna if I twist off the wrong one...
So which one is it...the top smaller wrench point, the middle or the largest one being the lower one.
Thanks,
Wally
you have to unscrew the antenna from the base.
this is how my antenna looked liked when I took mine apart.
http://i15.photobucket.com/albums/a372/color01joy/P1020077.jpg
http://i15.photobucket.com/albums/a372/color01joy/P1020079.jpg
http://i15.photobucket.com/albums/a372/color01joy/P1020078.jpg
Mine looks somewhat different. This one is from an '06. If yours looks like this:
Leave the right most piece in place. It's bolted on from under the support. Hold it stationary with a wrench above the support.
The center piece threads onto the left most piece. Put a wrench on either the folder or the middle set of flats. They should unscrew together as in the center photo.
