greyghost Posted September 30, 2007 #1 Posted September 30, 2007 Does anyone have the GMAX helmet. The 3/4 helmet is very light and comes with 3 visor attachments clear sheild, smoked sheild, and a black visor. The inside seems a bit cheap looking but the overall appearance seems quite good. Any comemts????
Guest TFD69 Posted October 1, 2007 #2 Posted October 1, 2007 How's the fit? You will not care about looks if the helmet causes headaches. Even a little irritation will magnify into intolerable in very short order. Have someone hold the helmet while your wearing it, try turning your head left and right. It should be snug enough that you can not rotate inside the helmet but loose enough not to cause any pressure points. Helmets that are D.O.T. rated and fit well are my primary considerations. Happy hunting
Guest JGorom Posted October 1, 2007 #3 Posted October 1, 2007 I have had the predecessor to the GMax for over a year now (great helmet), and the wife has a GMax in 3/4 size...they are one of the best values on the market and Yes...they are D.O.T. approved.
greyghost Posted October 1, 2007 Author #4 Posted October 1, 2007 Thanks guys One thing I really liked was the light weight of the helmet. I sometimes have muscle tension in my neck and I think the lighter helmet will help with this problem. So I think I will get one.
