We went for a short ride yesterday & 86 VR quit in the middle of the street.
Idled it into a lot & removed LH fairing, where I saw my throttle cable, broke in two about 2 inches from the idle screw. Towed home.
The metal curved shroud & spacers were balancing in place & I saved them.
I've looked-up the info on this fix & it looks like a nightmare.
One end moves with the carb linkage [finger] & the other moves with the throttle.
Which of the 4 cables is this?
What is involved in fixing this?
Thanks in advance for any info.
Check out my older post here... about half way down the page...
http://www.venturers.org/Forum/viewtopic.php?t=12374&highlight=throttle+cables
There are four cables... two to the junction box and two out to the carb...
oops... 5... there's also the cruise control cable...
http://bergall.org/temp/venture/throttlecable.jpg
To replace cables,
You have to remove the left side upper fairing, only way to get to the cable joint as shown in the above photos, from the manual.
I did mine about 6 months ago, the 4 new cables were about $40.00.
Most of the job is getting the fairing removed, and re installed.
is it me or??? those links don't work and I logged in. I get the message "The topic or post you requested does not exist" ....??
The Fairing is not that big of a job just be carefull and make sure you have all the screws out before you start pulling on it they get brittle with a few years on them.
Guest Popeye
I found price for both cables, about $42. I'm not worried about the cruise cable, since I almost never use it & only 38k on scoot.
Spoke to some techs in the area & they say it's a 2 hr job....IF you know what you're doing. [doesn't]
Everyone agrees the faring [off/on] is the lion's share of the work.
Only 38k miles & steel cable broke, at curve in tubing...a serious design flaw, there, it seems.
The rest of the cable looks like brand spankin' new.
rick.
those links go to another forum. venturer's .org or something like that. that's why you can't open them.
lol
got to pay your annual dues, to read those posts!
just jt
Guys,
I'm sorry that my link wasn't a "free" link...
the remaining test was ...
The push-pull cable from the grip runs down to the throttle cable housing mounted on the left frame rail under the left upper fairing shell to a "transfer box" AND there is also attached the actuator cable for the cruise control coming out the bottom. .
Coming out the rear of that box is the second pair of push-pull cables to the carb.
So: Now you have to pull the left side fairing off to get to this "junction box". You might as well replace the entire set of 4 throttle cables?
Order All 4 of the Cables.
a quick check...
41V-26311-00-00 Cable #1---- $9.58
41V-26312-00-00 Cable #2----$10.44
41V-26313-01-00 Cable #3---- $11.72
41V-2631J-00-00 Cable #4---- $9.58
Page 3-83 of the service manual describes cable replacement in the
throttle cable housing... installing each cable in the hole that's marked on the cable "spool" inside.
There's a torsion spring in there and that also needs attention on disassembly/assembly.
  • 2 years later...
Guest byekryam
You have prices here for cables, but where did you purchase them?
Thanks,
Woody
  • 2 years later...
Don't buy from Partzilla- you will regret it. All 3 of my recent order were the wrong parts. I'm into it for $40 (including returns) in shipping and nothing accomplished. And their customer service lines are overloaded. And the live chat is shut down due to overload. And their "within 48 hrs" email service ain't within 48 hrs- haven't heard back yet!
Edit: Boats.net is a Partzilla operation.
Thanks I was on their webpage looking at the parts...lol I am now going with Cheap parts I think. But I may cheap out and just get the one cable. The rest look good as new...lol I'll check em again before I buy. But it wasn't as bad as I thought to get at the cable box. SO I may roll the dice on the one. Its #3. Thanks for all the help , guys
