elmicko Posted December 6, 2009 #26 Posted December 6, 2009 Put mine down in my garage Thanksgiving weekend. Got a few projects to do. Repair and reinforce cracks in faring. Sync carbs and replace diaphragms. Replace battery cables and run extra ground to frame from starter. Change Oil & filter. Hope I remember how the whole thing goes back together.
Yammer Dan Posted December 6, 2009 #27 Posted December 6, 2009 Squidley said: Yep, the FJR rearend is the same gear ratio as the Vmax, and will slide right into the '89 Bought one off ebay shipped to the house for $80 You might not be the only one that knew that!!! E-Bay huh? I visit there once in a while.
SilvrT Posted December 6, 2009 #28 Posted December 6, 2009 Eck said: Here is my list: Start it Fill it up with gas Ride it. Clean it Wax it Start it Fill it up with gas Ride it. Clean it Wax it Start it Fill it up with gas Ride it. Clean it Wax it :biker::biker::biker: is the above some kindof "dig" due to the fact you ride a GW ???
bongobobny Posted December 6, 2009 #29 Posted December 6, 2009 ^^^^^ Yah, Eck, and besides that, do thewords "me" and "Bite" have any meaning to you???
mother Posted December 6, 2009 #30 Posted December 6, 2009 dont forget to check the blinker fluid. i couldn't resist picking on you too.
RedRider Posted December 6, 2009 #31 Posted December 6, 2009 On the Venture - Change brake and clutch fluid Oil and filter change Rear end oil change Lube drive shaft splines Set float levels in carbs Check and adjust valve clearances Install handlebar risers Hopefully - Install gauge set in place of cassette Hopefully - Install Russell Day Long seat On the KLR650 - Change oil and filter Change out front sproket to a 16T Install handlebar risers Change out tires I also have a '66 Rambler I need to get on the road and repair the convertible top mechanism in a '72 Skylark. Paint the master bathroom, redo the kids bathroom, paint a couple of bedrooms, redo the laundry room, replace ceiling in finished basement. It's a good thing winter is long up here. RR
Woody Posted January 7, 2010 #32 Posted January 7, 2010 Ok, mine is done, who else has completed there project? Thanks to all the posts on this site I was able to do it. passing lights with a relay, lowered front end one inch, added luggage rack, added Aux Jack. [ATTACH]40013[/ATTACH] [ATTACH]40014[/ATTACH] [ATTACH]40015[/ATTACH] [ATTACH]40016[/ATTACH]
dingy Posted January 7, 2010 #33 Posted January 7, 2010 Add cruise control from 88 - ready to put in Replace wiring harness & switches - ready to put in Upgrade instrument cluster - ready to put in Replace valve cover gaskets - ready to put in Fix valve clearances - Done, need to do again on new engine Replace transmission - don't have to do, 1300 doesn't have 2nd gear issue Replace clutch plates - don't have to do, well within specs Replace & relocate TCI Upgrade starter & battery wiring Replace rear shock with one with spring - ready to put in add grease zerts to rear linkage - done Possibly rewind stator Clean carbs - done Clean & paint frame New stuff to do Replace 1200 engine with a 1300, put cams in from my 1200 replace valve springs with vmax springs, there on the way here Add 2002 FJR rear end ready to go in, need shim from sky doc 17 Probably put clutch in from my 1200, I like helical spring set up :mo money: Gary
Bubber Posted January 7, 2010 Author #34 Posted January 7, 2010 dingy said: Add cruise control from 88 - ready to put in Replace wiring harness & switches - ready to put in Upgrade instrument cluster - ready to put in Replace valve cover gaskets - ready to put in Fix valve clearances - Done, need to do again on new engine Replace transmission - don't have to do, 1300 doesn't have 2nd gear issue Replace clutch plates - don't have to do, well within specs Replace & relocate TCI Upgrade starter & battery wiring Replace rear shock with one with spring - ready to put in add grease zerts to rear linkage - done Possibly rewind stator Clean carbs - done Clean & paint frame New stuff to do Replace 1200 engine with a 1300, put cams in from my 1200 replace valve springs with vmax springs, there on the way here Add 2002 FJR rear end ready to go in, need shim from sky doc 17 Probably put clutch in from my 1200, I like helical spring set up :mo money: Gary Well who let this guy post that he already did these winter project? LMAO Must be some kind of sicko to get that done already. Good on ya Gary..................but no bragging OK? Bubber
dingy Posted January 7, 2010 #35 Posted January 7, 2010 Bubber said: Well who let this guy post that he already did these winter project? LMAO Must be some kind of sicko to get that done already. Good on ya Gary..................but no bragging OK? Bubber Some of us still don't have jobs, Like some of you have found. Lots of time to tinker, if it just wasn't so friggin cold.. By the way, how is the new job? Gary
DAKn2 Posted January 7, 2010 #36 Posted January 7, 2010 (edited) Got this one scoped out since my 97 is brand new (to me) and I can't ride it 'cause of the weather: - Remove Cobra Drag Pipes and sell them - Find good, clean '97 RSTD OEM mufflers - buy and install - Remove trailer hitch and sell it - Remove/replace Coolant - Remove/replace all Brake fluid including Clutch lines - Drain/replace rear fluid - Change oil/filter - Replace air filter - Replace spark plugs - Install additional lighting in the rear; at a minimum add night rider bar - Install Stebel Air horn - Install Ram mount for GPS and figure out how to run power to it Edited January 7, 2010 by DAKn2
BradT Posted January 7, 2010 #37 Posted January 7, 2010 I liked Freebirds answer, but why Dust off the cover ? I won't even see mine till spring, but I will charge the battery a few times as it is out on the workbench. Brad
saddlebum Posted January 7, 2010 #38 Posted January 7, 2010 lets see ---think about putting more lights on ---have a beer ---think about how i am going to put them on ---have a beer ---think about how I plan on wiring them ---have a beer ---think about what I will need ---have a beer ---dodge the wife and her honey do list ---have two beer's OOPS bed time guess I will have to work on this some more tomorrow
Eck Posted January 7, 2010 #39 Posted January 7, 2010 Hey Bubber, Just checking in on your progress.. So how many of your listed tasks have you done so far?.......... I have done all of the tasks I listed......................
Bubber Posted January 7, 2010 Author #40 Posted January 7, 2010 I have a friggen hanging heater in the garage and it is just to dang cold to go out there and get started. It has been below zero for a while and I Hate it! Next week it may reach freezing whoopy friggen do! Did I mention I hate winter the older I get? Jobs is coming along. Boss is good to work for and the job pays the bills. I wasn't my dream job but I think I can grow to like it. It is a lot closer to the house and cost a lot less in fuel to get here. GOOD FOR ME! All you boys down south enjoy the nice weather your having I am sending as much south as I can. I think Squidley is loading it into his trailer when he comes back. Bubber
Yammer Dan Posted January 7, 2010 #41 Posted January 7, 2010 1. Check the cover on the bikes 2. Keep the Warden warm til Spring 3. Watch the snow fall.
Grandpagak Posted January 8, 2010 #42 Posted January 8, 2010 repaint the 86 a blue metalic.. i think?? but changed my mind bookoonumerouse times already...:bang head:
