I was sitting here thinking about the long hard winter and all the things I had planned to do to my bike to keep me busy. Well I made a list and posted it below. Got me to thinking what all you people were planning over this down time to keep yourselves busy without going totally nuts. :missingtooth:
Well here is my list....... where is yours? :banana::banana::banana:
WINTER VENTURE PROJECT
  • Speed bleeders
    • (4) front brakes, rear brakes, and clutch
    [*]Change brake fluid in front and rear brakes
    [*]Reflectors add on to saddle bag guards
    [*]Knee wind deflectors (from BuddyRich) on lower leg fairings
    [*]LED lights to illuminate wording in license plate (RED)
    [*]LED light under tank (BLUE)
    [*]LED taillight from Strobes& More 21 pattern flashing LEDs (RED)
    [*]Chrome accent strip on top of saddle bag lid
    [*]Paint (black) clear wind deflectors on fairing
    [*]Dress up right and left hand air boxes
    [*]Oil rear shock with fork oil to stop squeaking
    [*]Add HD hooded visors to passing lights
    [*]Spark plugs
    [*]change oil and filter
My list is
Fix the rest of the oil leak on the left side (prolly stator wire or shifter gasket)
Replace brake lever light switch
Replace front tire, (picked up a nail)
Check over brake pads
Check radio connections , radio not working, and run cables for rider intercom
Oil change and lube everything
Figure out where occasional low speed, cold temperature speedometer growl is coming from
Ahh forgot one, r and r the starter as it occasionnally would bind
Brian
Edited by friesman
my list.
repair book.
pull tires off take to a place to get my new ones installed
while there off put the new rotors on all 3.
new brake pads and bleed the brakes.
install the radio i bought from a member .
take apart the tape player it quit about 2 weeks ago?
figure out how to remove the old gages? and replace with the nice ones i got from a member. old ones worked but had a crack on the cover and filled up with water?
firgure out how to pull the carbs if thats the cause. i put sea foam in and maybe too much?
so start with new plugs. check on the cable updates i heard about on this site for the starter drag when it sits for about a week. i got a gel battery just 2 weeks ago. and have to figure out how to shut off the sensor on the monitor? no hole in the new battery. oil change.
and then figure out why PO put a fan switch on the bike? im thinking the bike thermo dont work right. or it got hot at one time?
i did notice at 44,000 miles there is a record and proof the PO had second gear done.
then just clean the bike up. and latter decide how to remove fairing as i might get it painted.
I'm wanting to do a couple of oil changes
Replace front and rear tires
Change out rearend to the FJR1300 that I have
See how far around the state of Texas I can go
....and hopefully find a job :whistling:
Continue working two full-time jobs, riding Venture to work each day
Continue raising three kids, including Boy Scouts and Cub Scouts
Put gas in bike every couple of days as needed
Continue work as treasurer of local fund to help people with heating & power bills
Change oil again in late Jan or early February
Hope for the chance to take some rides on Saturdays
Clean crud off the bike every ten days or so
Check and adjust tire and shock pressures every ten days or so
May ride to Florida to visit parents with remaining vacation days
Probably will need new rear brake pads during this time
That about does it.
Goldie:
Replace the wiring harness
replace all the bushings in the rear suspension
Rewbuild/replace entire cooling system
McGuiver 2nd gen saddlebags from Sexi on to bike
Complete repaint???
Sexi:
Install H.O. Stator?
Get ready for Tirking
Project '85:
Clean up plastic parts
Start painting parts
Clean and polish metal parts
Wife:
Routine maintenance...
Ya I was waiting for comments from those below the Mason-Dickson Line to chime in.
While you can be enjoying much warmer weather in your neck of the woods, we in the great white North now have time to do those things we put off.
Get those projects posted so we can all see what others are doing and encourage others to do the same, help out with parts, or give some help or just some friendly advice.
I am not looking forward to the long Winter but at least I have my 1 stall garage/ workshop with a hanging natural gas heater to go hide out in when I hear the lonely call of my scoot wanting to be pampered.
So ifin your riding good on you, ifin your wrenching lets hear what your up to.
If you ain't got a list you won't get to it. WOW who does that sound like, gotta go the warden is coming.
LOL
Bubber.
Add cruise control from 88
Replace wiring harness & switches
Upgrade instrument cluster
Replace valve cover gaskets
Fix valve clearances
Replace transmission
Replace clutch plates
Replace & relocate TCI
Upgrade starter & battery wiring
Replace rear shock with one with spring
add grease zerts to rear linkage
Possibly rewind stator
Clean carbs
Clean & paint frame
thankfully "Kato", my 87 is doing good, i am planning on putting in different pickup coils at some point, but my 86 "the bear" ...well...lets just say the list of what im not planning is alot shorter than the to-do list.
ok mine is short, and hopefully the same goes for the cool weather.
add passing lights
add extra aux jack
lower front end
add trunk rack ( got all this for xmas)
looking and thinking of away to get just a little more sound from exhaust but not to load, I just want to hear her moan.:D
Not much to my bike. New tires next spring which I install.
I have to install a Buckeye stator in a buddy's Venture (contrary to some thoughts-it is the same as Ricks Motorsports since I have installed both). Install a relay in another buddy's Venture passing lights. Work on my 81 Honda GW-service.
Ride when I can!
:farmer:
FJR1300???? did I miss something???
YOU HAVE TO WATCH VERY CLOSELY, but I will say, his fingers never left his hands! :yikes:
Took you long enough to see that didn't it? :stirthepot: LOL
Yep, the FJR rearend is the same gear ratio as the Vmax, and will slide right into the '89
:) Bought one off ebay shipped to the house for $80
In the new year I hope to;
Remove and completely clean the carbs
Replace front a rear tire
Properly grease the drive shaft
Replace front wheel bearings
Grease and re-torque steering head bearings
Replace the fork fluid
Install progressive fork springs
Upgrade fork brace
Change brake fluid, final drive fluid and oil and filter
Give it a good cleaning and polishing and wait for spring (probably in the hot tub with a beverage and cigar while I contemplate attending the 2010 Venture Rally) :D
  • Replace clutch basket with an “I” basket … (done)
  • Replace tires (put 130 on front)
  • Install angled valve stem on front and point the one on rear to the right
  • Lube driveshaft splines with Moly60
  • Lube rear wheel splines and pins with Moly60
  • Change diff oil
  • Swap rear brake pads
  • Check/adjust steering head bearing
  • Reposition Stebel air horn inside fairing
  • Install wiring block inside fairing and cleanup “my” wiring mess
  • Have some pin striping or graphic paintwork done
  • Install Clearview windshield
  • Sync carbs
  • Replace plugs
  • Replace oil & filter
I'm not sure if it was you I mentioned this to at St Cloud, or someone else in the past couple weeks, But...
Paint the back side of the plexiglass, the glass effectively becomes an 1/8" clear coat and looks really sharp..
Just my $.02, Scooter Bob
Here is my list:
Start it
Fill it up with gas
Ride it.
Clean it
Wax it
Start it
Fill it up with gas
Ride it.
Clean it
Wax it
Start it
Fill it up with gas
Ride it.
Clean it
Wax it
:biker::biker::biker::biker::biker::biker: :thumbsup2:
