jrcain32 Posted November 30, 2009 #1 Posted November 30, 2009 I need to rebuild both the Master and Slave clutch cylinders on my '99 RSV. Where can I get the kits? Anyone have part numbers?
skydoc_17 Posted November 30, 2009 #2 Posted November 30, 2009 Hey James, Here are the Part Numbers for the rebuild kits for the Master Cylinder: 2SKU: 3GM-W0099-00-00 CYLINDER KIT, MASTER (CLUTCH)1$23.76http://www.yamahasportsplaza.com/modules/oemparts/images/partsadd.gif And the slave Cylinder Complete: 27SKU: 1FK-16381-11-00 PUSH LEVER COMP.1$62.39http://www.yamahasportsplaza.com/modules/oemparts/images/partsadd.gif And the Slave Cylinder Rebuild Kit: 29SKU: 26H-W0098-00-00 PUSH LEVER SEAL KIT1$15.70http://www.yamahasportsplaza.com/modules/oemparts/images/partsadd.gif These prices are from Southwest Motosports, you can take the part numbers and go to partshark.com and beat them by a few bucks. As far as the slave cylinder goes I have had much better luck buying the new Slave Cylinder than the rebuild kit. Brake fluid is nasty stuff and if you have a leakng slave, it is usually the Cylinder body that has failed. The Master Cylinder rebuilds fine but you will need a good pair of "snap ring pliers". I purchased the Craftsman (sears) professional series and they did a fine job. If you want to purchase from Southwest Moto just click on "Add To Cart" and you are good to go. If you have questions about the rebuilds, PM me. Hope this helps, Earl
