thetoyho Posted November 28, 2009 #1 Posted November 28, 2009 I have an 85 Venture Royale I am having trouble with the rear brake. The calipers seem to be fine, but no matter how many times I pump the brake pedal I can get a hard pedal and the brakes to work. I have bleed the brakes thoroughly, but no stiff pedal or breaks. Don't see any leaks. Would this be the rear master cylinder? Thanks for any tips.
LLonearth Posted November 28, 2009 #2 Posted November 28, 2009 You may already know this but in case you do not, the rear brake is linked to the left front rotor also and there is another bleeder point by the top of the right front fork.
dingy Posted November 28, 2009 #3 Posted November 28, 2009 (edited) [ame=http://www.venturerider.org/forum/showthread.php?t=21537]Reverse bleeding? - VentureRider.Org[/ame] http://www.venturerider.org/forum/showthread.php?t=15245 Look at threads above for bleeding ideas. Also remember the anti dive valve on front end. Bleeding the rear brake on these bikes will will give you gray hair. I could be wrong on this next one, but I don't think an 85 had the bleeder by the top of the fork. I think this started with the 86 model. Gary Edited November 28, 2009 by dingy added 2nd thread
Rocket Posted November 28, 2009 #4 Posted November 28, 2009 I could be wrong on this next one, but I don't think an 85 had the bleeder by the top of the fork. I think this started with the 86 model. Gary Correct, a line fitting is loosened & re-tightened at the high point, until the air is out of there.... A real PITA, it is a bit easier to do, with all the right side fairing plastic off, for access.......
Dano Posted November 28, 2009 #5 Posted November 28, 2009 I could be wrong on this next one, but I don't think an 85 had the bleeder by the top of the fork. I think this started with the 86 model. Gary You would be correct on this one, sir. The 83-85's are a PIA to bleed, start with the front caliper, then the anti-dive, THEN do the rear caliper. If you want REALLY good brakes, go with the stainless steel lines, switch out your forks to 86 & up and go with the R1/R6 calipers and bigger master cylinder. You could also de-link the front to the rear and use an early VMax brake line set to connect the fronts. Good winter projects. Dan
bobcat Posted November 29, 2009 #6 Posted November 29, 2009 I have an 85 Venture Royale I am having trouble with the rear brake. The calipers seem to be fine, but no matter how many times I pump the brake pedal I can get a hard pedal and the brakes to work. I have bleed the brakes thoroughly, but no stiff pedal or breaks. Don't see any leaks. Would this be the rear master cylinder? Thanks for any tips. When was the last time the rear caliper was rebuilt?
zlMark Posted November 30, 2009 #7 Posted November 30, 2009 You may already know this but in case you do not, the rear brake is linked to the left front rotor also and there is another bleeder point by the top of the right front fork.I better go look for that bleeder!! Just cleaned out the rear brake caliper and bled the whole system, I'll bet there is still air!
CrazyHorse Posted November 30, 2009 #8 Posted November 30, 2009 Or you could delink and not have to worry about that front line air anymore and have a normal braking system.
warthogcrewchief Posted November 30, 2009 #9 Posted November 30, 2009 You could also install a bleed port at the top of the system (located near the steering head). It is similar to the '86-'93 VR bleeder port. I think it makes thing a bit easier, but even with my '89, it took me a while to bleed the rear system.
