FROG MAN Posted November 22, 2009 #1 Posted November 22, 2009 OK guys yesterday at some point I lost both rear brake lights on my 04 silverado. I drove the last 300 miles with my daughter tailing me tight with her Subaru just to make it here.I believe I have a wiring problem. The brake fuse is fine,tail light bulbs are fine, and the third brake light that sets high above the rear glass works OK. This tells me the brake light switch is OK.The ground to both rear tail lights is probably OK as the rear turn signals,park lights etc are OK. I'm thinking maybe the master feed line comes into some connection plugs under the frame behind rear bumper. I'll check it out today when it warms up here. I got my volt meter with me just no wiring diagram.Those rear electrical plugs may be corroded.Nothing like plenty to do on vacation.
Owen Posted November 22, 2009 #2 Posted November 22, 2009 A lot of vehicles use 2 switches on the brake peddle for the brake lights. One for the regular lamps and one for the 'third' brake light. Just a thought...
midnightventure Posted November 22, 2009 #4 Posted November 22, 2009 If I can get this to attach maybe it will help.I guessed at the year. This is for a 2004 2 wheel drive. Those systems are usually kind of generic.
footsie Posted November 23, 2009 #6 Posted November 23, 2009 On my 97 the brown wire broke at the clamp on the frame just before the plug at the rear. had a hard time finding it, the covering was intact. Gregg
Yammer Dan Posted November 23, 2009 #7 Posted November 23, 2009 Hey Gerald. You could get Mamamo to sit on the tailgate with a red flag to let people know when you are going to stop!!!! Hope you find it. Warn me when you are coming back!!
MamaMo Posted November 23, 2009 #8 Posted November 23, 2009 Hey Gerald. You could get Mamamo to sit on the tailgate with a red flag to let people know when you are going to stop!!!! Hope you find it. Warn me when you are coming back!! RED FLAG YAMMER I'll remember you.
Yammer Dan Posted November 24, 2009 #9 Posted November 24, 2009 Did I tell you I'm thinking of Moving??? Did you get lights fixed??
flb_78 Posted November 24, 2009 #10 Posted November 24, 2009 If you have the tow package, the wiring adapter that tees in could be bad.
FROG MAN Posted November 24, 2009 Author #11 Posted November 24, 2009 Got brake lights fixed. Checked brake pedal switch and removed and reseated both bulbs in tail light. Everything OK now???? Not sure exactly what fixed it.
Yammer Dan Posted November 24, 2009 #12 Posted November 24, 2009 You won't have to put Mona in the back...
mini-muffin Posted November 24, 2009 #13 Posted November 24, 2009 Hope you can hobble fast yammer. :whistling:I'll let you know how mad she is later I'll be seeing them for Thanksgiving. Maybe she'll be in a better mood by then.:crackup: Margaret
Yammer Dan Posted November 24, 2009 #14 Posted November 24, 2009 I still got the walker with wheels on it.......
