There is an 84 Mk1 Std near my house, has the 2nd gear problem but is really clean ~27K mi and CHEAP. Haven't driven it yet but owner says it runs well, he had it sold but the buyer balked on the test drive when it "had a shifting problem". He said "make me an offer, I want it out of my way"
Thinking of buying as a parts store for my 88 but my research says a lot of parts wont fit (but a lot will). Can the Gen 1 experts here confirm or correct my list.
Thanks
Parts that WILL fit ????
Carbs
Clutch basket
Starter
Stator
Regulator/rectifier
TCI
Fairing plastic
header pipes & Collector
Misc Electronics components
Gas tank
Fuel Pump
Radiator & Fan
Instrument cluster
Clutch master & slave
Brake master (F&R)
Engine (If I fixed 2nd gear)
Wheels (minus rotors)
Parts that WONT fit ????
Bags
Trunk
crash bars
pumpkin
drive shaft
u joint
rotors
brake calipers
fork
What 84 Mk1 parts fit an 88 Mk2
Carbs
Clutch basket
Starter
Stator
Regulator/rectifier
TCI
Fairing plastic
Gas tank
Fuel Pump
Radiator & Fan
Instrument cluster
Brake master (F&R)
Bags
Trunk
crash bars
pumpkin
drive shaft
u joint
rotors
brake calipers
fork
clutch cover (condor)
Head light assembly "
As far as the rear rim, you have to change out the Grey plastic cover before you can swap out the rim, they are diferent due to the difference in the pumpkin. ( bongobobny)
just trying to keep one list so can be useful to someone else in the future.....:smile5:
Edited by chabicheka
