dingy Posted November 21, 2009 Posted November 21, 2009 (edited) I have made the following write up of the process of cleaning the throttle side switch housing that came off of a 1983 Venture. This switch is from a Venture without cruise control. The 1983 to 1985 models should be similar. The pictures show the switch completely removed from the bike. I would recommend removing switch from bike if you perform this cleaning. There are a number of small springs and ball detents that are very easy to lose unless you have a large well lit working area. If you are unable to open the PDF file, PM me with your email address and I will send it to you. I have detailed the clutch side switch in another thread. Picture below is of the switch detailed in this PDF file. 38774.pdf Edited February 14, 2016 by Freebird
