Dmnordin Posted November 19, 2009 #1 Posted November 19, 2009 I have an '83 std Venture. When it's mid-30ish degrees or below, the tach is very sluggish and won't read above 3K rpm's. This concerns me because I currently commute an hour each way to work in mid to low 20 degrees. I found one other thread about this, but didn't see any conclusive fix. Is the tach mechanical, drive via cable from the drive train, or electronic, driven from the computer board in the dash? Does anyone have a good fix? Thank you!! Doug
Condor Posted November 19, 2009 #2 Posted November 19, 2009 I have an '83 std Venture. When it's mid-30ish degrees or below, the tach is very sluggish and won't read above 3K rpm's. This concerns me because I currently commute an hour each way to work in mid to low 20 degrees. I found one other thread about this, but didn't see any conclusive fix. Is the tach mechanical, drive via cable from the drive train, or electronic, driven from the computer board in the dash? Does anyone have a good fix? Thank you!! Doug The Tach is electronic. Put an heating pad on it overnight. . Ya gotta remember it's been doing it job for over 25 years. It's a wonder it even works at 20 degs...heck I know I wouldn't....
rhncue Posted November 19, 2009 #3 Posted November 19, 2009 I have an '83 std Venture. When it's mid-30ish degrees or below, the tach is very sluggish and won't read above 3K rpm's. This concerns me because I currently commute an hour each way to work in mid to low 20 degrees. I found one other thread about this, but didn't see any conclusive fix. Is the tach mechanical, drive via cable from the drive train, or electronic, driven from the computer board in the dash? Does anyone have a good fix? Thank you!! Doug My 83 does that when it gets down to the mid 50s and below. After awhile it loosens up and works correctly. I believe it probably needs some very light weight sewing machine oil on the bearing in the tachs head. I just never think of it when I have the dash apart for other reasons. Dick
84xj1100 Posted November 19, 2009 #4 Posted November 19, 2009 My XJ1100 is like that.......for the first 10 miles or so it's sluggish and refuses to go beyond about 3k....after riding for 10-15 miles it loosens up and works just fine. Once I head home after it's been sitting in the warmth of the sun it works just fine.
Dmnordin Posted November 19, 2009 Author #5 Posted November 19, 2009 Thank you for the info! Do you know what the mechanism is that is driven from the board? Thanks, Doug
84xj1100 Posted November 19, 2009 #6 Posted November 19, 2009 My XJ1100 does exactly the same thing. On those cold mornings it's extremely sluggish and won't go above 3k. Quite often after I've riden for 10-12 miles she loosens up. When I head home, after it's sat in the sun all day and temps have increased a bit there's no problem. I never did persue it, I just accepted it.
Venturous Randy Posted November 19, 2009 #7 Posted November 19, 2009 My 83 does that when it gets down to the mid 50s and below. After awhile it loosens up and works correctly. I believe it probably needs some very light weight sewing machine oil on the bearing in the tachs head. I just never think of it when I have the dash apart for other reasons. Dick This should fix the needle movement. Light oil and a little cleaning should work for another 25 years. RandyA
Rocket Posted November 20, 2009 #8 Posted November 20, 2009 The Tach is electronic. Put an heating pad on it overnight. . Ya gotta remember it's been doing it job for over 25 years. It's a wonder it even works at 20 degs...heck I know I wouldn't.... Sorry Jack, but you don't work at any temp........ How long, is your project list, now???????? ,
Condor Posted November 20, 2009 #9 Posted November 20, 2009 Sorry Jack, but you don't work at any temp........ How long, is your project list, now???????? , 'Bout that long......
