Shipper Posted November 15, 2009 #1 Posted November 15, 2009 I assume that you put the "restricters" in the rubber tubes per the instructions in the manual, but which adapters (if any) do you use for the 2nd gen RSTD? All of the directions given on the forum for using the carbtune are great, but none mention setting up the carbtune. Thanks for any help!
Thom Posted November 15, 2009 #2 Posted November 15, 2009 (edited) i have used mine on 1stgs and 2ndgs and did not use adapters , just pull off 1 of your rubber nipples and stick the rubber hose on , the nipple will have a clamp on it , i think there is some pics in the tech library Edited November 15, 2009 by Thom darn spell checker making me look dummer
Shipper Posted November 15, 2009 Author #3 Posted November 15, 2009 Do you have the restricters in your carbtune hoses? I couldn't find any pics in the tech library. Glad I don't have to worry about the adapters.
Thom Posted November 15, 2009 #4 Posted November 15, 2009 yes there is 1 per hose , mine are about 12 in. from the end
