Guest Bountyhound Posted November 14, 2009 #1 Posted November 14, 2009 (edited) Just put a trunk light on my 2006 Venture today and works great. I found as a suggestion on earlier forum to get from autozone a WE6-197 led strip brake light. I mounted right to bottom of trunk. It was suggested to use brackets. I had some super stick 3M foam double backed tape used for heavy mounting. It seems to hold excellent since light bar is light weight. If not I will use brackets later. Did the suggestion with two diodes, one with 330 ohm resistor in line for running light and direct from lower brake light. This conversion worked well and in my opinion looks good. At $25.00 for light, diodes and resistor and tube of solder and some shrink tubing, you can't go wrong if you are on a budget and want more visibility. I am going to try and find some chrome caps for the ends where the original plastic brackets were located to dress it up some. For the money I saved, I am now going to invest in a lowering kit as next project. Edited November 15, 2009 by Bountyhound
Kirby Posted November 14, 2009 #2 Posted November 14, 2009 Sounds great but, you know the rules..., we gotta have pics.
