  barend said:
Condor: standard fork brace, have looked at but not purchased one yet.
That low speed wobble is probably caused by the wheel on the sidecar being midship to the bike, and at low speed with different rolling resistences you're getting a wobble until the gyro effect of the wheels takes over. It might also cause the forks to react unevenly with just a little independant side-by-side action. Not saying a fork is the cure, but it can't hurt.
  Monty said:
Low speed wobble sounds like a bent wheel or maybe a bad tire on it. That kind of problem usually goes away after you speed up.
I am in need of a new front tire, so if it is the tire, that would be good news!
