Long Tall Posted September 28, 2007 #1 Posted September 28, 2007 Hey All: Thought I would post so everyone could check their hard bags for a potential problem....While putting on the bag rails I dropped my allen wrench down between the metal plate in the bottom of the bag and the cloth material going down the side....Big hands, so decided to take the bag lid off....There are four screws that hold this plate on...three across the outside edge and one right in the middle of the bag....When I went to loosen the first one along the outside edge I though it was stripped.....On closer inspection I noticed it was broken...These three screws go into molded holes (stud like-raised about 1/2") as opposed to the one in the center of the bracket....On looking further, I discovered that ALL three molded studs were broken...This plate has never been off before....First attempt....I decided that during the install, (factory) they may have been over torqued...Took to the dealer with the three broken studs (with screws)...He just called and Yamaha is replacing the bag under warranty... Thought you might want to remove the foam thing from the bottom sometime and check these...Basically, the only thing holding on the bag lid was the one screw in the middle of this mount and the material support along the bag and lid sides....This happened on the left bag (from drivers position)....Right bag was OK... George in VA 2006 BC Venture
