I need a few parts for my cruise addition project.
I am adding a 1988 cruise control to my 1983 plain jane
I need the bracket that mounts to the triple tree that the cruise light pod screws to. Also the rubber grommet that goes around the ignition switch. They are items #13 & 14 on attached PDF of parts listing. Anything from 1986 thru 1993 should work.
Also I need a set of throttle cables from a bike that had cruise (83-93). I have the pulley box that connects the upper and lower cables. I didn't realize cables were different until I got the bike stripped down yesterday.
Will the cables from a second gen work for what I need? I see several sets of these on Ebay for very little. They look very similar in pictures.
Also could use a 1983 TCI unit.
A clutch side foam grip would also be nice. I got the throttle side one with the right hand electrical control.
Also, I bought a rear shock with a spring. The one I bought is from a 1987. I did not get the air line that goes into the right top of the shock. The one on my 83 that only has the air bag goes into the left side of the shock and is too short. Or, if anyone can tell me what the threads are going into the shock, maybe I can get an adapter. I have an extra fork tube air set with shrader valve. I might be able to couple to existing line with one of the air lines from this if I knew thread size.
If you have any of these PM or email me price with shipping.
Thanks
Gary
:fingers crossed:
Edited by dingy
