dingy Posted November 3, 2009 Posted November 3, 2009 (edited) I am in the process of installing cruise control on my 1983 Venture Standard. I have purchased almost all of the items I need to do this upgrade from ebay. Prior to installing the parts, I will be disassembling the ones that I can and cleaning them. I have made the following write up of the process of cleaning the front and rear brake switches and the clutch switch that came off of a 1988 Venture. The pictures show the switch completely removed from the bike. The switches detailed are from a Venture with cruise control, switches from non cruise control equipped bikes are different. These switches may be very similar to 1983-1985 Ventures. If you are unable to open the PDF file, PM me with your email address and I will send it to you. I have detailed the throttle side switch and the turn signal switch in other threads. 38049.pdf Edited February 14, 2016 by Freebird
