Aussie Annie Posted November 2, 2009 #1 Posted November 2, 2009 Someone with a XVZ1300 (naked) over here asked me if I knew the valve settings. Nope, but knew where to come and ask:thumbsup2: So help away guys.......................................
BuddyRich Posted November 2, 2009 #2 Posted November 2, 2009 If its a second gen just look in your trunk. There's a label on your's that has the tolerances.
Aussie Annie Posted November 2, 2009 Author #3 Posted November 2, 2009 Nope, just looked and all I got is tire info sticker. Valve setting info label must be in the same box as the CB I never got! (and it's 2nd Gen)
RandyR Posted November 2, 2009 #4 Posted November 2, 2009 Intake .11 to.15 Exhaust .16 to .20mm measured when cold Your friend should download the Maintenance Specifications .pdf file in the tech library. There's also a thread in the tech section here on how to check and replace shims if necessary.
Aussie Annie Posted November 3, 2009 Author #5 Posted November 3, 2009 Thanks RandyR, will pass on info
