ronjolly Posted October 31, 2009 #1 Posted October 31, 2009 Installing a c/t: once mounted use a good lube STP or WD-40 this will help the c/t seat to the rim. With these lube several tires we have done have seated with 75-80 lbs. We have mounted Kumbo,Nexen and BFG,All seated with less air ...AFTER instalation ride for a while,,there is a breakin faze for the driver. You will notice the tire seems to sway if the tire preasure is to hi,,tire preasure does better in range between 30-38 u need to play with it. Tha breaking inincerased,,the tire pad is larger.. The cost for a c/t $70 plus 44k miles,,,for a m/t $130 + and mabe 5k (If u ride hard) enjoy and PLEASE take it slow for a few miles... "PRAY FOR OUR TROOPS"
