dingy Posted October 16, 2009 Posted October 16, 2009 Files Updated on 10/28/2009>> All Audio circuits now on main page, so that all schematics are now just one page. Other minor corrections done to all schematics. Text realigned for easier reading Some Line types changed for easier reading. Gary I have completed the 1st Generation schematics. My goal in doing this is to make them easier to read and reduce the number of pages needed to display the information. I have used color and line types to make the wiring easier to follow. In some cases I could not use the exact color that is being represented due to visibility and printing issues. For example yellow is hard to see on the screen and does not print well. The previous posting for the 1983-1985 models have been replaced by what is included with this post. The 1983 differs significantly from the 1984-1985 models in the areas of Flasher, Hazard, Starting Circuit Cut-Out Relays, the Hazard Switch, Canceling Unit & Diode Pack. The files for the 86-89 models that were previously posted have been revised slightly and are now at Revision B. Major corrections done included coils were numbered incorrectly in Simplified Circuit & the Flasher Relay Assembly has been updated to include flasher information. The 1990 major changes from the 1986-1989 models were the TCI, coil pick-up & fuel pump control. This post supersedes all previous posts I have done in regards to the 1st gen wiring diagrams. All 1st gen's are included in this post. The files will look best when plotted at 11" x 17" size or larger. Office Max and Staples as well as others can do this for you for a minimal charge if you want a printout. I paid $1.00 for an 11" x 17" color print at Staples. 83 Yamaha Venture TK Wiring Diagram Rev C.pdf 1983 Venture XVZ12TK From 1983 Yamaha Venture Owners Manual. 83 Yamaha Venture Royale TDK Wiring Diagram Rev C.pdf 1983 Venture RoyaleXVZ12TDK From 1983-1985 Yamaha Venture Service Manual 83 Yamaha Venture TK Simplified Circuit Diagram Rev C.pdf 1983 Venture XVZ12TK From 1983-1985 Yamaha Venture Service Manual, page 7-1 83 Yamaha Venture Royale TDK Simplified Circuit Diagram Rev C.pdf 1983 Venture Royale XVZ12TDK From 1983-1985 Yamaha Venture Service Manual, page 7-1 83 Yamaha Venture electrical info.pdf This file is a compilation of various sheets from the 1983 Yamaha Venture Service Manual that would be helpful when working with electrical system. They are not modified in any way, just as they appear in service manual. 84-85 Yamaha Venture L Wiring Diagram Rev C.pdf 1984-1985 Venture XVZ12L From 1983-1985 Yamaha Venture Service Manual 84-85 Yamaha Venture Royale DL Wiring Diagram Rev C.pdf 1984-1985 Venture Royale XVZ12DL From 1983-1985 Yamaha Venture Service Manual 84-85 Yamaha Venture L Simplified Circuit Diagram Rev C.pdf 1984-1985 Venture XVZ12L From 1983-1985 Yamaha Venture Service Manual, page 7-1 84-85 Yamaha Venture Royale DL Simplified Circuit Diagram Rev C.pdf 1984-1985 Venture XVZ12DL From 1983-1985 Yamaha Venture Service Manual, page 7-1 84-85 Yamaha Venture electrical info.pdf This file is a compilation of various sheets from the 1983-1985 Yamaha Venture Service Manual that would be helpful when working with electrical system. They are not modified in any way, just as they appear in service manual. 86-87 Yamaha Venture DS Wiring Diagram Rev D.pdf 1986-1987 Venture XVZ13DS/DSC From 1986-1993 Yamaha Venture Service Manual, page 8-41. PDF file pages #467 & 468 of 496. 88-89 Yamaha Venture U Wiring Diagram Rev D.pdf 1988-1989 Venture XVZ13U/UC From 1986-1993 Yamaha Venture Service Manual, 1988-1989 Supplement. PDF file page #478 of 496. 88-89 Yamaha Venture DU Wiring Diagram Rev D.pdf 1988-1989 Venture XVZ13DU/DUC From 1986-1993 Yamaha Venture Service Manual, 1988-1989 Supplement. PDF file pages #477 & 479 of 496. 86-89 Yamaha Venture Simplified Circuit Diagram Rev D.pdf 1986-1989 Venture XVZ13DS/DSC - U/UC - DU/DUC From 1986-1993 Yamaha Venture Service Manual, page 7-1 thru 7-4. PDF file page #265 thru 268 of 496. 90-93 Yamaha Venture DA Wiring Diagram Rev C.pdf 1990-1993 Venture XVZ13DA/DAC From 1986-1993 Yamaha Venture Service Manual, 1990-1993 Supplement. PDF file pages #495 of 496. 90-93 Yamaha Venture DA Simplified Circuit Diagram Rev C.pdf 1990-1993 Venture XVZ13DA/DAC From 1986-1993 Yamaha Venture Service Manual, 1990-1993 Supplement. PDF file pages #492 of 496 86-93 Yamaha Venture electrical info.pdf This file is a compilation of various sheets from the 1986-1993 Yamaha Venture Service Manual that would be helpful when working with electrical system. They are not modified in any way, just as they appear in service manual.
