Files Updated on 10/28/2009
Minor corrections done to both schematics.
Text realigned for easier reading
Gary
I have completed the 1999-2009 Royal Star Venture schematics.
The 99-09 Yamaha Royal Star Venture Wiring Diagram Rev B file shows all the connectors and resembles the wiring diagram in the 1999 Yamaha Royal Star Venture service manual that is referenced in the Second Gen and Royal Star Technical Library on this site.
The 99-09 Yamaha Royal Star Venture Simplified Circuit Diagram Rev B file is the complete wiring for the bike in a much simpler format. Since the wiring connectors are not shown, components can be rearranged in a more logical format that reduces the wires running back and forth. Some of the switches are shown in a more convenient manner also. This file would probably be the one most used for trouble shooting.
I have also added a legend to this group to help users understand the schematics better.
If you find anything that needs changed on these schematics, let me know & I will fix it.
The files will look best when plotted at 11" x 17" size or larger. Office Max, Kinko’s and Staples as well as others can do this for you for a minimal charge if you want a printout. I paid $1.00 for an 11" x 17" color print at Staples. All you have to do is take the PDF file that you download to their store and they can print it.
Double click on underlined blue text below to down load the schematics in PDF format. Files were created in Adobe Acrobat 7.0.
99-09 Yamaha Royal Star Venture Wiring Diagram Rev B.pdf
From 1999 Yamaha Royale Star Venture Service Manual.
Pages 9-7 & 9-8. PDF file pages 485 & 486 of 487.
This file combines the MCU, Cruise Control Unit, Cruise switch & D.C. outlet systems on page #1.
99-09 Yamaha Royal Star Venture Simplified Circuit Diagram Rev B.pdf
I did this one from a blank sheet of paper. I could not find anything similar in the information I had available.
99-09 Yamaha Royal Star Venture electrical info.pdf
This file is a compilation of various sheets from the 1999 Yamaha Royal Star Venture Service Manual that would be helpful when working with electrical system. They are not modified in any way, just as they appear in service manual.
Edited by dingy
It would be good to know if someone has done a detailed comparison of the wiring for the new RSTD 05-09 (RIP) with the RSV. Is the wiring the same color codes where appropriate and just ignore the wiring on the audio, and components that are not on the RSTD (like emergency flasher)?
Thanks for these diagrams. I expect they'll get lots of use. If I recall, you were asking for a small donation to the web site if down loaders were so inclined?
Gary, That's some good work there. By far the best I have seen bringing all the components together. THANKS!
I'm sure Don will put it into the read only Tech section when he see's it.
Edited by BuddyRich
WOOOOHOOOOO!!!
GREAT JOB!!!!!!
What program did you draw it in???? It is very nice!!!!
I am making two 11x17 copes to hang on the wall, one in the garage and one at work.
It is Much easier to read than what Yamaha produced in the service manual.........
I just re uploaded the simplified schematic file & the wiring diagram file due to a cosmetic change in the way some wires were drawn.
The same links in the top of this thread will now bring up the new & improved version.
I eliminated the ones that had the X's and O's in them. I made up a different linetype to replace these.
The new ones have one dot or 2 dots in them.
I never really liked the X & O linetypes for a schematic. It made it appear in some places that two crossing wires connected. Problem is there are only so many linetypes with dashes and spaces available.
I didn't change revision level for drawings as this is only a cosmetic change.
Any one that does not like new style please return it with your receipt for a full refund.
:Laugh:
Gary
I have updated the schematics to help make them easier to read.
I have staggered the wire color call outs where they are clustered together, such as by the instrument cluster connector. Not much done to the RSV ones in general though. The 1st gens have been changed much more and they have also been updated. All files are now one sheet.
Hopefully this will be last change to them, I probably have a lot more than a couple hundred hours creating all of these. There are 16 different versions.
Gary
