footsie Posted November 20, 2009 Posted November 20, 2009 What grade steel did you make your dog bones from, and could we make a set 1/2 inch longer. Gregg
Freebird Posted November 20, 2009 Posted November 20, 2009 If you make them 1/2 inch longer, that is going to lower your bike a lot. Is that what you are after?
Bloodbought1 Posted November 20, 2009 Posted November 20, 2009 The dog bones in my kit are shorter to raise the rear. FYI
Kirby Posted November 20, 2009 Posted November 20, 2009 What grade steel did you make your dog bones from, and could we make a set 1/2 inch longer. Gregg Picture below. I think 1/4" inch in linkage difference will yield 1" in actual height. Please forgive my writing and drawing, I don't use MS Paint too much. And yes, you do have to go longer to make the bike shorter. Just think in reverse!!
footsie Posted November 21, 2009 Posted November 21, 2009 What grade steel did you make your dog bones from, and could we make a set 1/2 inch longer. Gregg Picture below. I think 1/4" inch in linkage difference will yield 1" in actual height. Please forgive my writing and drawing, I don't use MS Paint too much. And yes, you do have to go longer to make the bike shorter. Just think in reverse!! Kirby Then maybe make a set just a 1/4 INCH longer, want to drop approx 1 inch off the back. What did you cut from. Gregg
footsie Posted November 21, 2009 Posted November 21, 2009 If you make them 1/2 inch longer, that is going to lower your bike a lot. Is that what you are after? Want to drop the rear approx 1 inch. Gregg
