flb_78 Posted October 16, 2009 #1 Posted October 16, 2009 Took 125psi to seat the beads. I'll get some pics up soon.
Jerry W Posted October 16, 2009 #2 Posted October 16, 2009 That's a lot of psi's. You still going to make it over tomorrow?
Greener Posted October 16, 2009 #3 Posted October 16, 2009 I'm still not convinced! Sorry. Avons next!
gunboat Posted October 16, 2009 #4 Posted October 16, 2009 way to go forrest, looking forward to meet you in person saturday at jerry w's. don c.
BigBoyinMS Posted October 16, 2009 #5 Posted October 16, 2009 Took 125psi to seat the beads. I'll get some pics up soon. That's more pressure than usual! But you got it done.
tsigwing Posted October 16, 2009 #6 Posted October 16, 2009 Took 125psi to seat the beads. I'll get some pics up soon. Took about a 100 to seat my BFG Radial TA. Asked Discount Tire if that was unusual and they didn't think it was any big deal.
dragerman Posted October 16, 2009 #7 Posted October 16, 2009 Took 125psi to seat the beads. I'll get some pics up soon. Tire installers use a paste (not sure what it’s called) to help seat a tire. It helps to put a ‘thin’ smear of that stuff on the ‘rim’ beads first before you even try to mount the tire. Then put another ‘thin’ smear to the tire bead before you mount the tire. Once you’ve done that and slipped the tire on the rim you may have to reapply another ‘thin’ smear to the same areas but it’s better to do it that way to ensure the paste is contacting the surfaces where it needs it the most.
1rooster Posted October 16, 2009 #8 Posted October 16, 2009 Took 125psi to seat the beads. I'll get some pics up soon. Took 500 psi to seat mine..100 psi 5 times.Got er did.
footsie Posted October 24, 2009 #9 Posted October 24, 2009 The paste you are refering to is called Murphy lube, comes in a green and white bucket with red lettering. As a friend of mine, who owns a tire shop says, its slicker than snot. Gregg
flb_78 Posted October 24, 2009 Author #10 Posted October 24, 2009 Murphy's is some slick stuff. We used it at the truckstop mounting tires.
wes0778 Posted October 24, 2009 #11 Posted October 24, 2009 [ame=http://www.youtube.com/watch?v=aEdOWEFALdA&feature=related]YouTube - Mounting tires with explosives[/ame]
flb_78 Posted October 24, 2009 Author #12 Posted October 24, 2009 That'll get em to take air, but it doesn't seat the bead. I had to do that to my Kumho. Im assuming it was stored on it's side. The beads were pushed in. I need to buy a cheap camera to record this kind of stuff.
footsie Posted October 24, 2009 #13 Posted October 24, 2009 A little goes a long way, but thats how you mount some tires.
Wanderer Posted October 24, 2009 #14 Posted October 24, 2009 I thought about that, but it would scare the bajeebers out of me.
Kirby Posted November 15, 2009 #15 Posted November 15, 2009 I didn't have any ether so I used something else. No, I not going to tell you what it was on this forum because it is very dangerous, moreso than ether!! The reason I am not telling is because some idiot who has never been expose to this stuff will try it and use too much and will wind up killing himself. BUT.., if you use ether you might want to reinstall the valve core before doing this or be very quick with the air hose, because this doesn't seat the beads and the tire will pull back away from the rim if not.
Rocket Posted November 15, 2009 #16 Posted November 15, 2009 The paste you are refering to is called Murphy lube, comes in a green and white bucket with red lettering. As a friend of mine, who owns a tire shop says, its slicker than snot. Gregg In the vehicle workshops here on Base, it is nicknamed "Monkey Snot"..............
footsie Posted November 15, 2009 #17 Posted November 15, 2009 The way we use to mount the tubeless grader tire, we placed them in the tire CAGE, the hooked the air hose to them, with the air flowing it only takes a small squirt of ether, and then you don't lose the seat.
CaptainJoe Posted February 12, 2010 #18 Posted February 12, 2010 Back in the day, we use to put a little dawn dish washing liquid, maybe 5% to 95% water in a container that hung on the tire machine. Apply that liberally around the rim and tire beads with a little cotton tipped metal swab and the tire will seat effortlessly. Here's a trick, do the above prep then place a ratching tie down strap around the circumference of your tire. Your beads should be touching the rim now. If not apply more pressure with ratchet. Start air into tire and take strap off when you hit about 15 lbs pressure. Then seat. Like i said before , if your tires lubed it should pop on effortlessly. I also like to apply mixture before taking old tire off, it realy helps. Shouldn't have to ever use more than 50 lbs. to seat a tire or you stand a good chance of ruining it. That being said, I'll admit I dont know anything about Truck tires, but if they take more than that I'm going to be in the next room. Know a guy that was leaning over his quater midget race tires and was blown through the floor of his house. He lost many many body parts and went through years of surgery. Another thing, have more than one tire gauge. If they start to stick buy a new one. Its not worth a tire blowing up on you.
CaptainJoe Posted February 21, 2010 #19 Posted February 21, 2010 (edited) Well, The deal went thru. I am now the proud owner of a 2007 Midnight Venture. Speedo reads 492 miles, it still has the breakin oil in it as it's suppose to be swapped out at 600 miles. As soon as I get the title back will take to the Yamaha dealership to do a once over and get the registration switched over to my name. SHE SURE IS A BEAUTY. Not a scratch oh her and I believe a bargain at $13,000, PLUS, shes still under warranty, Sweeeet!... After the tires wear out am planning on trying a ct on rear (Kumho?) with a Avon e3 on the front. Question: Is the Kumho, the roundest profile tire, out of the 6 or so tires that will fit? Edited February 21, 2010 by CaptainJoe 5 sets of opposable thumbs... LOL
BigBoyinMS Posted February 21, 2010 #20 Posted February 21, 2010 They all have a rounder profile than most people think. The Kumho has done great for me. For three times the price of a Kumho, the Vredestein should be a good tire too. The Federal is about the same price of the Kumho and Pegscraper has had good luck with his. It's pretty much which one you can find but my choice is the Kumho. Good Luck! FYI, Dunlop makes the E3. Avon is the Venom. Both good tires.
