bongobobny Posted October 15, 2009 #1 Posted October 15, 2009 OK I just got done sorting out some parts and here's what I'm trying to get rid of next. I have 2 left mirrors in fair condition, one has rashed chrome, the other has "whited out" reflective surfaces around the edge of the mirror. Both are serviceable and better thsn no mirror at all. $5 each to cover the flat rate shipping to US. I also have a couple of MK1 front fairing frames in good shape. Pay shipping or pick up and they are yours. I also have 2 pair of stock horns. Pay shipping, probably $5 flat rate box will work. 3 pair of MK1 passenger grab rails in good shape, rust free. Pay shipping. I have a ton of other parts I will be getting rid of over the winter. If there is something specific you are looking for PM me...
Winesap7 Posted October 16, 2009 #2 Posted October 16, 2009 As you go through your stuff see if you have a fuel tank sending unit-----that works and will fit on my 90 VR. Thanks
steve crossley Posted October 16, 2009 #3 Posted October 16, 2009 Winesap7 said: As you go through your stuff see if you have a fuel tank sending unit-----that works and will fit on my 90 VR. Thanks Byron i had a time i thought i needed a new one also. so i got a new one and i still didnt work . then i found a bad ground wire so check carefully i then hooked up the old one after fixing ground wire and installing new unit and it worked fine . so i have the old one that works great . if you need one .just let me know! Steve:big-grin-emoticon:
bongobobny Posted October 16, 2009 Author #4 Posted October 16, 2009 I have a spare too but not sure what condition...
Evan Posted October 22, 2009 #5 Posted October 22, 2009 Bob - I have been meaning to replace the headlight lens in my 88VR which has a rock chip. Any chance that you have one of these?
Poledar Posted October 26, 2009 #6 Posted October 26, 2009 Bob, By any chance---looking for hardware to hold a Ventureline backrest on. The hex bodied nuts especially. Best wishes from an expatriate New Yorker!! Poledar:fingers-crossed-emo
a1bummer Posted October 26, 2009 #7 Posted October 26, 2009 I'm in need of valve covers and a cam cap, side cover, etc., for the engine that fell off my trailer. Don't remember what else for sure. And I've been looking for the handle from a fuel petcock for my 84.
bongobobny Posted October 26, 2009 Author #8 Posted October 26, 2009 a1bummer said: I'm in need of valve covers and a cam cap, side cover, etc., for the engine that fell off my trailer. Don't remember what else for sure. And I've been looking for the handle from a fuel petcock for my 84. I should have a couple of things you are looking for. Give me a couple of days to check out what I have and I'll PM you...
BradT Posted October 27, 2009 #9 Posted October 27, 2009 bongobobny said: I should have a couple of things you are looking for. Give me a couple of days to check out what I have and I'll PM you... What you doing Parting out Blondie Brad
bongobobny Posted October 27, 2009 Author #10 Posted October 27, 2009 No, I'm parting out all the spare parts I bought for Goldie but never used or needed. What a fool I was thinking I'd need spare parts for a 1st gen...
BradT Posted October 28, 2009 #11 Posted October 28, 2009 bongobobny said: No, I'm parting out all the spare parts I bought for Goldie but never used or needed. What a fool I was thinking I'd need spare parts for a 1st gen... Agree when you go buy a Second Gen ! Brad
shadow Posted November 1, 2009 #12 Posted November 1, 2009 I need an upper fork tube for a '93. By the way, anybody know if an upper fork tube from an '86 will work on a '93? I know the fork assembly is a different part # for the 2, but I only need to replace the tube that mounts to the triple tree and slides through the seal. Mine has a scratch and causes the seal to leak.
Rocket Posted November 1, 2009 #13 Posted November 1, 2009 shadow said: I need an upper fork tube for a '93. By the way, anybody know if an upper fork tube from an '86 will work on a '93? I know the fork assembly is a different part # for the 2, but I only need to replace the tube that mounts to the triple tree and slides through the seal. Mine has a scratch and causes the seal to leak. Same upper fork tube for all 1st gens. Main difference in the part # was if the tube shipped with or without, the bushing on the bottom. Also "Forking by Frank" makes the tubes, in full sets or 1/2 sets & was about half price of Yamaha, when I got a set. http://www.frankmain.qpg.com/
phill12 Posted November 7, 2009 #14 Posted November 7, 2009 I'm in need of a stock seat and the Computer Mointor System (CMS) It's the insturment panel, in middle of the dash that reads out the differnt checks and has the Fuel gage and clock. for a 1992 Phill pandllbiker@olp.net
bongobobny Posted November 7, 2009 Author #15 Posted November 7, 2009 Phil, I tried unsuccessfully twice last night to email you. Both bounced for some reason. Anyway, no on both acounts. I am actually in need of a CMS or my '85 project bike. The one out of that went to another membger this spring. You may be able to fix yourself if you know of someone handy with a soldering iron. Probably the issue is a broken solder conection on the main connector for the module. Elsewise dash assemblys regularly appear on fleabay but usually go for $50 or more plus shipping. Per previous post in this thread, the seat is spoken for. They to regularly appear on ebay and usually for a reasonable price except shipping can cost an arm and a leg depending on the location and the dealer...
