I need to put 2 new rivets in one of my bub mufflers to hold the chrome tip on.
I was told not to use aluminum however, if I use steel, they will rust. I haven't seen any stainless steel rivets. Has anyone had trouble with using aluminum?
Like I said, I don't want them to rust. Not attractive.
Thanks
Greg
I would recommend stainless. I doubt aluminum would hold up.
http://www.stanleytools.com/default.asp?TYPE=CATEGORY&CATEGORY=STAINLESS+STEEL+RIVETS
Wayne
I have the aluminum ones holding a deflector lid on the top of my propane heater and I can tell you, that lid gets WAY HOTTER than mufflers will ... no problems so far. But, just my "opinion" . If it was me, I'd go with the alum ones and see what happens... they're easy enuf to replace.
Thanks
Greg
hi greg the aluminum will work just fine. thats what i used on my bubs. i belive i got a rivet kit from harbor freight, came with diferent size rivits and a install tool.
don c.
Aluminum rivets don't last on the pipes due to the vibration. They work loose and finally fail. Use the stainless rivet, you won't lose the tip.
WOW! Thanks everyone. I really like the idea of tapping it and using a stainless screw.
Don't know why I didn't think of that. You guys are great for waking up the brain.
CHEERS! Have a beer on me. :group cheers:
Greg
