camos Posted October 7, 2009 #1 Posted October 7, 2009 Just learned about this DriSlide Bike-Aid lubrication product. Looks like the perfect solution for lubricating linkages and cables but it costs about $12 on Amazon and costs $17 to ship to Canada, typical. Anyone in the Great White North familiar with it?
hillrider Posted October 7, 2009 #2 Posted October 7, 2009 If it's what it used to be, it's graphite suspended in a freon or alcohol base that evaporates fast. But if there's a low spot in the cable, it can puddle over time and multiple uses and cause a bind.
camos Posted October 7, 2009 Author #3 Posted October 7, 2009 The Website say Dri-Slide is a molybdenum disulphide lubricant. According to what I read, the lubricant is carried by a solvent which is supposed to evaporate and leave the lubricant behind.
Bubber Posted October 8, 2009 #4 Posted October 8, 2009 The Website say Dri-Slide is a molybdenum disulphide lubricant. According to what I read, the lubricant is carried by a solvent which is supposed to evaporate and leave the lubricant behind. OK here is what I can tell you about molybdenum disulphide lubricant. It is typically used as a dry lubricant and most times when it is applied correctly...... the surface is blasted 1000 grit for adherence to the part. The part is then sprayed and cured, some are air cure others require a 325F for 10 to 30 minutes, There are may different types of molybdenum disulphide they all have a little different formula depending what the function is. The molybdenum disulphide lubricant works its way into the pores of the metal and is still useful over time as the surface wears So there is my:2cents: Steve
camos Posted October 8, 2009 Author #5 Posted October 8, 2009 Thanks for the explanation Bubber. So that seems like it would be a particularly good lubricant for the shift linkage which needs constant attention during wet weather.
Rocket Posted October 8, 2009 #6 Posted October 8, 2009 Just learned about this DriSlide Bike-Aid lubrication product. Looks like the perfect solution for lubricating linkages and cables but it costs about $12 on Amazon and costs $17 to ship to Canada, typical. Anyone in the Great White North familiar with it? I just use PJ1 Cable Lube, available at Cdn Tire, every winter on the cables, locks & ignition switch.
camos Posted October 8, 2009 Author #7 Posted October 8, 2009 I just use PJ1 Cable Lube, available at Cdn Tire, every winter on the cables, locks & ignition switch. That would be much more convenient, do you also use the PJ1 on the shift linkage? Does it stand up very well to wet roads? Thanks
Rocket Posted October 8, 2009 #8 Posted October 8, 2009 That would be much more convenient, do you also use the PJ1 on the shift linkage? Does it stand up very well to wet roads? Thanks Have not used anything on the linkage, aside from grease on the arm's main pivot point. Did ok on the year round, Mill Bay - Victoria commutes. I had rode in some real good downpours, riding over the Malahat.
camos Posted October 8, 2009 Author #9 Posted October 8, 2009 OK, thanks. The Malahat is a real fun ride in the rain.
