Brown Angel Posted October 10, 2013 #26 Posted October 10, 2013 More pics and progress. Pic 1 The wire connections under the seat. Pic 2 The dressed out wiring under the seat. Pic 3&4 Light bar installed on Trunk with running lights on. Pic 5 The wiring in the trunk. The red rectangle is the diode board. Pic 6 The floor back in the trunk. Pic 7 Running lights from 50 yards Pic 8 Running lights Pic 9 Brake lights Pic 10 Brake lights from 50 yards The reflector backing was reinstalled using double sided foam tape 1/32 thick, with five 1.5 x 2 pieces and the original 3 screws. I have not glued the reflector back on since the backing was rather flimsy once the reflector was removed so I have to have it mounted to the trunk to hold proper shape for gluing. I have not yet reinstalled the reflectors. I am waiting to see if I want to increase the Turn signal portion to be more visible from the back. Increasing the turn signal area will decrease the brake light area. I may need to get someone to follow me to see what it looks like on the road. Totally am going to do this ! Love it.. Thanks:clap2:
Flyinfool Posted October 10, 2013 Author #27 Posted October 10, 2013 Let me know before you start, there are new LEDs coming out all of the time, there are better ones out now than what I used.
