OK
Someone has had to have had this problem.......
The Bike runs great if it starts --- That is the problem --- :thumbdown:
2006 RSTD 40,000 miles
Normal operation ----
I turn the key
The Fuel Pump makes at tick about 3 seconds
I pull the choke
Bike starts
I let it warm up while I get my gear on
Off I go
Problem ----
Let the Bike sit for a week or so
I have the battery tender on Battery checks out fine
I turn the key plenty of power
The Fuel Pump is silent
I pull the choke
Bike starts --- Barely an idle -- put put put --
I can not give it any throttle or push the choke or it stalls
It puts until it I assume it runs the carbs dry then stalls
It can take an hour or so until I can get it to run
last time this happened I left it alone
I had the shop come and pick it up
I got on it in the garage turned the key (Habit)
Tic Tic Tic
the bike started up as soon as he unloaded at the shop
and he cant find anything wrong with it
I told him keep it and call me in 2 weeks when it wont start
What is it that determines if there is pressure in the carbs
When I turn the key what happens next ??????
5 times this has happened
I can recreate the problem just let the Bike sit for a week or so.
I have put close to 4,000 miles on it this summer
as long as I don't let it sit no problem at all
Hey Dave,
Earlier this summer Seaking came to Pa. for a visit, and much to my sorrow, his bike was plagued with what sounds like the same problem you are describing. 2 dealers later and a new set of coils later it turned out to be the fuel pump! It seems that the fuel filter is in such a bad place on the Second Gens. that it is a real bear to change it regularly. well that is a shame because it sure does play heck on the fuel pump! One new fuel pump later and he has been enjoying some carefree miles on his bike since. I am hoping he will relate his story here if he sees this post. PM me if you need help with this issue.:thumbsup2:
Earl
Thanks for getting back to me Guys
I was under the idea of the fuel pump or a relay
When I spoke the the guys at the shop I told the shop what input you gave
Then I called Yamaha and it wont be covered under warranty
because the fuel pump is working
If it were completely shot then it would be covered
and I would be standing on the side of the road someplace
A little disappointed
Oh well
