Sleeperhawk Posted October 24, 2009 Posted October 24, 2009 Hey Ponch I bought the Equus gauges, but after seeing your instructions, I now understand your brackets will not work as designed. Not sure what holes have to be opened and how you are slotting the mounting brackets. Especially since the Equss gauge has ceramic piece that screws Here are some pics of your bracket and faceplate with the Equss gauge As soon as I get some more made, I'll post an ad and then start shipping them. If anyone who has this setup has any coments, please let them fly. I'm not fishing for compliments here, just issues you may have with the install. I already know there is some mods required if you use the Equus gauges. Nothing major, you just have to open up the holes in the dash a little and slot the mounting holes in the mounting brackets.
Ponch Posted October 24, 2009 Author Posted October 24, 2009 I talked to George this morning about the Equus install. From what I have gathered from others, on two of the gauges there is a dimple or notch that will line up with the mounting bracket that can be drilled and a sheet metal screw inserted. The hole in the short leg of the bracket may have to be slotted a little. Make sure that the outside measurement of the brackets at the width is a little less than the opening for the casstte player (5" I believe).
Sleeperhawk Posted October 24, 2009 Posted October 24, 2009 I talked to George this morning about the Equus install. From what I have gathered from others, on two of the gauges there is a dimple or notch that will line up with the mounting bracket that can be drilled and a sheet metal screw inserted. The hole in the short leg of the bracket may have to be slotted a little. Make sure that the outside measurement of the brackets at the width is a little less than the opening for the casstte player (5" I believe). Well I was going to use the Equus gauges, even tapped them to fit the very sort Allen head bolts that I had in stock, but after cutting the holes in the cassette slot, put the gauges on the new plate, started to put into slots, but would not fit with the holes that were created because of the creramic nut they use, makes the gauges wider than 1.5 and I said the heck with them, I was not going to cut bigger holes, went to Autozone and got the Sunpro gauges. Ponch, so thanks for taking my call about the Equus gauges and the bracket setup.
Ponch Posted October 25, 2009 Author Posted October 25, 2009 ... it didn't work out. Don said he had to open up the cut out a little to make room for the nuts.
Ponch Posted October 28, 2009 Author Posted October 28, 2009 (edited) I have placed an ad now. I have a limited supply of steel plates ready to ship and will have some Polished Aluminum ready soon. http://www.venturerider.org/classifieds/showproduct.php?product=2433 Edited October 28, 2009 by Ponch added link to ad
Sideoftheroad Posted October 29, 2009 Posted October 29, 2009 just a quick fyi...I e-mailed Sunpro (Actron) about a 1.5" tach. They said they don't have anything in the works but would forward the info. on for consideration. Did this with some aftermarket shock companies too. Don't remember which one is which but one gave pretty short sweet answer "no" and the other also said they would put put it on some board for consideration. Heck at least they would consider it. Thought that is better than nothing.
Ponch Posted November 2, 2009 Author Posted November 2, 2009 You can now get the plates in chrome plated steel or BLACK chrome plated steel (especially for Midnight owners). http://www.venturerider.org/classifi...p?product=2433
Formerfuzz Posted November 8, 2009 Posted November 8, 2009 I want to give Special Thanks to Ponch for riding up to my place Saturday and installing my Gauges. We had a good time putting them on and they look great. Good Job!
Kregerdoodle Posted November 9, 2009 Posted November 9, 2009 Looks Great!!!! That Ponch is "Da Man"..... Nice Job!!
Ponch Posted November 9, 2009 Author Posted November 9, 2009 you're embarrassing me.... http://images.zaazu.com/img/shy-shy-timid-timorous-smiley-emoticon-000447-large.gif Thanks, Tim & Kreg. It was my pleasure.
Cougar Posted December 25, 2009 Posted December 25, 2009 This was my best attempt of Antiquing to try and match the MM Colors. Taking the pictures with the neon lights in the garage kind of changed the colors. Thanks to all the hard work that Ponch did for us already! He does excellent work! These are not hooked up yet. I need to find a different plug for my water side. I did order the one from on-line but the water censor probe will not go through the hole in the plug [ATTACH]39541[/ATTACH]
Jerry W Posted December 25, 2009 Posted December 25, 2009 Looks Great!!!! That Ponch is "Da Man".....
nowgrounded Posted November 5, 2011 Posted November 5, 2011 I too am interested in the full pkg of plates, gauges, etc. Is there a thought of providing these?
friesman Posted November 5, 2011 Posted November 5, 2011 its hard to say,because Ponch, the fellow that made up most of the plates had an accident with his bike and is recuperating. brian
Cougar Posted November 5, 2011 Posted November 5, 2011 (edited) I might have an extra (Ponch) plate laying around , I will have to look around for it though. (not sure if I still have it) As far as the rest , you can get yourself. READ all of the below link and also at the bottom of the pages you will see other links to click on as well. http://www.venturerider.org/forum/showthread.php?t=34281 Also you can go this way and use the back plate as shown here ( comes with the sunpro gauges) and your pretty much set. just need a couple adapters as you will find after reading through all the post. http://www.venturerider.org/forum/showpost.php?p=322564&postcount=130 Good Luck ! Jeff Edited November 5, 2011 by Cougar
Rockdoc Posted November 5, 2011 Posted November 5, 2011 Pity we can't get gauges that mimic the speedo style. A three all in one design would be great. Brilliant bracket idea though, well done.
