RSV gauge plates available soon
Ponch
From your 1st posting, is the middle pic of the polished plate?
Guessing the 5th pic is Don's?
Looks like from the colors they are the same '99 color as what I have.
The middle three pics are polished Aluminum. Don's is the fifth. He painted it to match his dash. Good job, too.
I would really like to have them. I too would prefer a tach in the package but it is not vital. Pretty dumb when it comes to this stuff but if the instructions are good I will give it a try.
It's really not that hard. I've been told the instructions are pretty clear. If after receiving the kit, you are unsure about it, you can call me with questions.
  • Replies 90
  • Created
  • Last Reply
Top Posters In This Topic
i most likely missed the post in all these posts about the gauges.
I like the Sunpro black background, but I want the Chrome ring.
All I find is the black ring, hate to buy both sets to swap rings.
Personally the white facing would be too bright (night time riding) and take a way from the speedo, unless there is a dimmer switch on the gauges.
:confused24:
I like the gauges but I'm questioning myself if I am capable of hooking them up. Also, I use my mp3 and I sure don't want to screw up the plug-in. All of that said, put me in for a set; every time I look at the cassette I think of taking it out and just adding storage or something.
Thanks
You don't have to lose the MP3 plugin. It has a cable with a 1/8" stereo jack inside the fairing. Just unplug it from the cassette, get a short extension cable at radio shack, and run it out so that you can still use it. There is a tech article on it here:
[ame=http://www.venturerider.org/forum/showthread.php?t=3905]Installing an Aux line splitter - VentureRider.Org[/ame]
Just use an extension cable instead of the splitter.
Watch yer mail next week.
Would this work out? Size is 1 7/8
http://www.denniskirk.com/jsp/produc...fCatId=&mmyId=
I have the Drag Specialties mini tach. Unfortunately, it measures about 2" at the O.D. of the bezel. That would work but it would overhang the top and bottom of the plate. Also, all three 1 1/2" gauges butt up against each other and just fit within the length of the mount plate. So, you would have a tough time fitting the tach in with two other gauges.
June would work, the first half of September is still August to me.
If I were headed south from Canuck land, I would choose early June, the end of September or October.
This is about a three hour job by yourself, two with friends, eight with lots of friends. :missingtooth:
Googling shows me about a 1400 mile trip on the most direct route.....probably a 3 day ride for us. We'll see how the vacations get set up next year, and see what comes up. Don't be too surprised if we invade your space for a week.....Texas should be big enough for all of us
randy:witch_brew:
Found these, now I wonder why these would not work.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=65210
Also, here is the manual for the gauges
http://www.harborfreight.com/manuals/65000-65999/65210.pdf
Yup, they'll work. I don't think HF offers a volt meter, though. All I found was the amp/water/oil setup. I prefer that setup myself as I already have a digital volt meter.
Randy, come on down, We'll leave the light on for ya.
I found this set with the volt gauge, but a little bit pricey
http://www.equus.com/product_info.php?product_id=6100&category_id=100_120
They are very good gauges from what I hear. They mount with a ring nut instead of a "U" clamp that the SunPro uses. They will still work with the gauge plate, but the holes in the dash have to be opened a little more and the brackets have to be attached via sheet metal screws instead of mounting to the studs on the back of the SunPro's.
I haven't installed the Equus setup yet, but Freebird and Rick Butler have and both said it wasn't hard to figure out.
Here they are about $20.00 cheaper.
[ame=http://www.amazon.com/Equus-6100-Black-Triple-Gauge/dp/B000EW0KX6/ref=sr_1_8?ie=UTF8&s=automotive&qid=1254737431&sr=1-8]Amazon.com: Equus 6100 Black Volt Triple Gauge Kit - Measures 1 1/2-Inches: Automotive[/ame]
:confused24:
The lighting on the white face gauges is not that bright. If it is, you can install a small resistor in the light circuit.
My tach light is blue and BRIGHT. I will install a resistor in that circuit.
Can Anyone in a 200 – 250 Mile radius from Va.Beach, help me with the installation of these gauges.?
I live in Culpeper and will be getting a set. I've never done it before, but the instructions from Goose don't sound to bad. I will be trying it. If I feel comfortable with it, I'll let you know and you can come on up.
Culpeper is not to far.. .. I picked a horse up in Culpeper..Not to long ago.
Please Let me know, when you installed you gauges.
Thanks
  • 2 weeks later...
For those of you waiting on me to get off my a$$ and make some plates, I'm working on it. My machine shop has stalled me for four weeks now, so I have been hand machining a few sets at a time to try to make a little progress.
I will try to get a dozen or so done this weekend. Also, I have a water jet fabricator who will make them for me in the future. As soon as I get a little capital, I will place an order with him.
I hope this doesn't put anyone off. I should never have started this thread before I had a stock on hand. Sorry.
It will be interesting to see how the Autometer gauges work out. I like the look of the gauges but didn't want to give up the three gauge setup. The Equus gauges I ended up going with are very nice also. It just seems that even with two gauges it is going to be a very tight fit even vertically.
Ponch - I failed to report that I got my set the other day ( sorry about that ) and I'm still hesitant about jumping in with the install.
The instructions are more than adequate and after reading thru them a couple times, they do make sense to me. I guess I'll just have to make time to tackle it.
I'll bet you can understand my apprehension when it took me 4 days to find a little nail in my bike tire.
We have lots of room down here in Texas for you all to stay..The cold may hold you up but if you want to put it on a trailer we can get em installed and have a great ride thru our hill country..Just a thought!
I think there is room. If Jarrex or anyone else sends me a two gauge set, I'll make a plate and try the install on my bike. If it don't work, I'll buy the gauges from the sender.
Dick, If you don't get it done before then, I'll do it for you at Freebird's Maint. Day.
I second that. Come on down, we'll do it here.
http://t1.gstatic.com/images?q=tbn:9h99sxAtkjcItM:http://upload.wikimedia.org/wikipedia/commons/thumb/f/f7/Flag_of_Texas.svg/800px-Flag_of_Texas.svg.png
Ponch,
PM sent, but I forgot to mention that there should be no need for you to buy the gauges, since I assume I could still use them in the area near the speakers, if they will not fit in the cassette deck opening.
Jerry
