distancerider Posted October 1, 2009 #1 Posted October 1, 2009 My 06 RSV came with stock RK pipes. I would like to get a little more sound. How do you drill the baffles and how many holes do you drill? I looked at some of the old posts but didin't see specifically how it should be done or how many holes? Thanks
Yammer Dan Posted October 1, 2009 #2 Posted October 1, 2009 My 06 RSV came with stock RK pipes. I would like to get a little more sound. How do you drill the baffles and how many holes do you drill? I looked at some of the old posts but didin't see specifically how it should be done or how many holes? Thanks 1. Usually with a drill. 2. Depends on how loud you want it. :rotfl: Couldn't resist. I'm sure someone will have that info. I really don't know.
distancerider Posted October 1, 2009 Author #3 Posted October 1, 2009 You have entirely to much time on your hands
eagleeye Posted October 1, 2009 #5 Posted October 1, 2009 here ya go, check this thread out. http://www.venturerider.org/forum/showthread.php?t=507&highlight=drilling+road+king+mufflers Steve
Yammer Dan Posted October 1, 2009 #6 Posted October 1, 2009 That should have all you need. Didn't want you to get tired while you were waiting!!
Kregerdoodle Posted October 1, 2009 #7 Posted October 1, 2009 I took a 3/4in solid rod and drove it all the way through each end, sounds good and not to loud.
Seaking Posted October 1, 2009 #8 Posted October 1, 2009 I took a 3/4in solid rod and drove it all the way through each end, sounds good and not to loud. Man, this place is becoming the "Comedy Fest"... "I didn't come here to be made fun of.. " No? where do you usually go for that then?? hehe Actually, how deep down inside the RK Pipes do you need to go before reaching those baffles?
Hummingbird Posted October 1, 2009 #9 Posted October 1, 2009 On one end you will see the "freeze plug" about 6' down and the other end it's about 10" deep. I use a metal cutting hole saw with one extension to drill them out. Drill one end then turn end for end and drill the second one. They will most likely stick in the muffler but I use a brass drift and drop it in the "deep' end and a little bouncing and they both come out the opposite end. Hope this helps - almost forgot - you might want to drill just one plug on each and test them for sound. I have both drilled out and the sound is great. Not annoying while cruising but really barks when accelerating.
Seaking Posted October 1, 2009 #10 Posted October 1, 2009 On one end you will see the "freeze plug" about 6' down and the other end it's about 10" deep. I use a metal cutting hole saw with one extension to drill them out. Drill one end then turn end for end and drill the second one. They will most likely stick in the muffler but I use a brass drift and drop it in the "deep' end and a little bouncing and they both come out the opposite end. Hope this helps - almost forgot - you might want to drill just one plug on each and test them for sound. I have both drilled out and the sound is great. Not annoying while cruising but really barks when accelerating. Thanks M8, I'll have a look next time I pull the pipes off for cleaning.. I had the Larosa downturns on the bike this past weekend and they are WAAAY too loud lol.. ouch.. but my RKs are a little too tame.. Cheers
Seaking Posted October 1, 2009 #12 Posted October 1, 2009 Think I got it. Thanks Guys!! Drop me a line when you get it done, I'd want to know how it went.. I'm still not 'visualizing' where to drill it and what to use as drills..
