Aussie Annie Posted May 21, 2010 Posted May 21, 2010 Hey, forgot to say thanks for the info on trike cover.
kj5ix Posted June 6, 2010 Posted June 6, 2010 I am also going to call Hannigan about this aux tank. I just got mine this year and I wish I had known they were working on one. Luckily I am not far from their Murray, KY location but if their dealers will be installing it that would be sweet too. What would you imagine your distance per tank would end up being with the aux tank? Did they tell you exactly where the tank would be? This will be a gravity fed system and not an electronic one, correct? Keith Fairfield Glade, TN I will let you know some time after the 19 th of this mo, I am getting the first one for production, and will be writing the installation most likely.... Jim has told me that it wont be available for retro fitting. My last kit had the tabs welded on the frame, but the tank wasn't ready for release. They just released it last Tuesday ( and I added it to the order ) That could be subject to change depending on the installer ( not all have a welder or can weld ya know) Not Gravity feed ( it would have to be on top of the tour pac for that...) Distance with the Aux Tank,,, what ever you get per-gal now plus 4 more of that number
