Stanman Posted September 27, 2009 Posted September 27, 2009 While out for a ride yesterday, I thought I heard a rhythmic squeak at low speed once in a while. I was 50 miles from home so I decided to run it home. Everything seemed fine at highway speeds, so I wasn't overly concerned. I thought it was the splines in the drive hub dry so I ran it in the shop to grease it. As I was removing the wheel I found it strange that the castle nut on the axle was barely finger tight. When I pulled the axle out I was very surprised as it was only 7 inches long with a nicely rounded end. The other end was still sticking out of the hub! I had to remove the final drive from the swing arm to get the wheel off the bike. Apparently the bearing was jamming at times and started rotating the end of the axle shaft. When I drove the axle out the inner race is still stuck on the shaft. Darn good thing the pinch bolt on the right side was tight so that end of the axle could not fall out. I don't even want to think of the concequences of something like that happening at highway speed. Now it looks like I'm going to have a fun time getting the outer race removed from the wheel. The right hand bearing came out reasonably easy. I just bought an axle from Pinwall Cycle and will have to order the bearings and seals from Yamaha Monday. By the way the splines have plenty of grease on them.
gunboat Posted September 27, 2009 Posted September 27, 2009 wow glade you made it home. as you i would hate to think of what could have happened. best reguards don c.
Squidley Posted September 27, 2009 Posted September 27, 2009 Glad to hear you caught it in time, rear tire problems....very bad
Marcarl Posted September 27, 2009 Posted September 27, 2009 Good to hear you made it safely, could have been a lot different. Use a Dremel tool to cut the race, takes a little while but it's quicker and easier. Bearings can be bought a lot quicker and cheaper at a local bearing store.
Snaggletooth Posted September 27, 2009 Posted September 27, 2009 Hey Stan. This is what I have if you want them. Mike
Ozlander Posted September 27, 2009 Posted September 27, 2009 I had that happen to me. I had to cut the brake caliper mount to get the axle out. I discovered the holes in the wheel, where the drive pins go, are open the the inside of the wheel. If you wash the wheel when changing tires, as I had done, you will get water inside the wheel. The water will end up on the back side the the needle bearing. Bad for the bearing.
Stanman Posted September 28, 2009 Author Posted September 28, 2009 I didn't wash the wheel when the tire was changed, unless the dealership that installed the tire did.
