Assuming you mean to get backoff lights, I'm traveling so don't have the exact part number. On my 09RSV I used the Kuryakyn one that is made for the Roadstar with the old style taillight( 03 and before I think). Not sure why, but Kuryakyn doesn't show this working for the RSV, but it was a direct plug and play fit for mine. Works great, plugs inline under the seat. I changed the taillight and rear turn lights to led. and makes unbleavabe difference for rear lighting. Someone will chime in on best place to get led taillight (in other words, I forget) but they sell a 100 light led board that is very bright. I will be home Friday if you still need part number, just let me know.
Got back early. The led tail light I used was Part # GEN-100-1157YAM which is the Genesis 100 Light board from www.customdynamics.com . I think the brightest board I have seen. I used a different led turn bulbs, but custom also has nice ones. The Kuryakyn #4613 RTB Controller. Kuryakyn shows this for 1600 Roadstar, but it works fine on my 09 RSV and is a true plug / play, ie comes with end plugs so no wiring. Not sure if plugs are the same on yours, but I think so. You might check with your local dealer to see if he has one you can look at, pull your drivers seat off and check to see if is a direct plug in. If so it is much easier then having to splic in wiring on the other ones. Comes with equalizers so everything blinks at right speed. I tried to post picture of back of mine, but really doesn't show how well it lights up. Hope this helps and good luck.
