Jimod Posted September 21, 2009 Posted September 21, 2009 My tape deck was faulty so I removed it. Now the radio won't work ! Do I have to have the tape deck installed for the radio to work ? Can I just bypass it if possible ? Jim O'D...........
scotty Posted September 21, 2009 Posted September 21, 2009 I believe you have to jump pins 1 and 7 on the cable that would pug into the cassette deck.
lonestarmedic Posted September 21, 2009 Posted September 21, 2009 Yep- Need to jump the pins. Might as well solder in a plug for an MP3 while you are there. Don't dispose of the cassette. I gutted mine and made a switch housing and storage box. Went fancy and wired my Garmin throught the 8 pin plug. Got an 8 pin receptacle an made it reversible if I want. JB
Jimod Posted September 21, 2009 Author Posted September 21, 2009 I just love you blokes !! I'll give it a try and let you know how it goes. Thanks Jim O'D Australia.
Jimod Posted September 21, 2009 Author Posted September 21, 2009 Thanks a million. I went out and bought a female 8 pin plug and bridged pins 1 & 7 as advised and everything works fine. Jim O'D......... Australia....The Land of OZ........where "Down Under is On Top "! :Venture:
Thom Posted December 27, 2009 Posted December 27, 2009 Yep- Need to jump the pins. Might as well solder in a plug for an MP3 while you are there. Don't dispose of the cassette. I gutted mine and made a switch housing and storage box. Went fancy and wired my Garmin throught the 8 pin plug. Got an 8 pin receptacle an made it reversible if I want. JB JB , i am trying to do the same thing , but i want to install my mp3 instead a garmin , did you use a sw. to go from radio to the input or you just jump pin 1 and 7 and wire in a plug for your garmin ? if anybody else knows please jump in , trying to get this done today , thanks
mbrood Posted December 27, 2009 Posted December 27, 2009 There's a couple ways to inject audio, using the original cassette cable... The earlier schematic assumes no casstte and you can see that opening the jumper between pins 1 and 7 tells the amp to switch to "cassette" source. Or you can have both cassette and external source... http://www.bergall.org/temp/venture/audio.jpg
Thom Posted December 27, 2009 Posted December 27, 2009 thanks ! so i can install a sw. between 1 and 7 , sw. on , radio works sw off leads for the tape deck are on , my weeks project !
lonestarmedic Posted December 28, 2009 Posted December 28, 2009 Actually, I think that switch ""on" arms the radio. Witn the radio off and the volume switch on the Garmin comes through the system. Power up the radio and the cassette connection drops out. I put a set of stereo plug-ins and switches in a small box. I turn off the radio and then select one of 2 inputs. I can run either the Garmin or an additional input. I have been experimenting with a box that has a priority override system. So, If you are listening to music, the GPS voice will trigger an override and come through. I have seen these devices on line and they sell for way more than they are worth. When I get my shop running again, I will play again. JB
a1bummer Posted December 28, 2009 Posted December 28, 2009 Yep- Need to jump the pins. Might as well solder in a plug for an MP3 while you are there. Don't dispose of the cassette. I gutted mine and made a switch housing and storage box. Went fancy and wired my Garmin throught the 8 pin plug. Got an 8 pin receptacle an made it reversible if I want. JB You wouldn't happen to have some pics of that would ya? Just for curiosity sake.
Grisolm1 Posted December 28, 2009 Posted December 28, 2009 I tried to wire my ipod through this connector. Volume was WAY too low, tried another MP3 player and had same issue. When first powered the volume was louder for a second or so then dropped to a whisper. I ended up using an FM transmitter but if anyone has a clue how to wire this up correctly I'll try again.
frankd Posted December 30, 2009 Posted December 30, 2009 (edited) Yes, the print for the tape player wiring on this site isn't quite correct. I also experienced low audio when I used what's shown. However, the correct leads are present in the cable to the tape player. I had no use for my cassette deck, so I completely removed it. A Sawzall with a little help from a hack saw will remove the pieces you don't need. Then I used an aluminum plate and a couple of small pieces of aluminum angle held together with some 6x32 screws and nuts. I used locking nuts where possible, but on the sides I had to keep it narrow so that it'd fit back in the bike, so I used regular nuts and some Lock-tite. I found that the blue and brown leads in the cable to the tape deck where the ones I needed for good audio. I have no idea what pins on the round connector you'd use, but I can tell you this......On the bottom (smaller) of the 2 system connectors, the blue wire is pin 3, the brown wire is pin 5, and ground is pin 7. If you want to use the round connector, just use an ohmmeter to find what pins on the round connector are attached to pins 3, 5, and 7 of the bottom system connector. The white wire in the cable is +12V, and the gray wire is the wire used to enable the tuner. I used a DPDT relay (Radio Shack 275-249) to turn the IPOD audio off when using the radio. Before I did this, if you left the IPOD on and switched the radio on, you heard both out of the speakers. I connected a diode (RS 276-1102 or 276-1101 or equiv) to protect the radio's switching circuit from the spike that is created when the relay is dropped out. Connect the diode so that the band on the diode is attached to the lead that is connected to the switch (positive). My wife found a hard plastic case for the IPOD that would allow Velcro to stick to it. The other half of the Velcro is stuck to the aluminum plate and this keeps the IPOD from bouncing around. With the IPOD equalization set to FLAT the treble was pretty hot. I switched it to SMALL SPEAKERS and it sounded much better. Now the IPOD works GREAT!!!! FrankD Edited December 30, 2009 by frankd Added schematic
frankd Posted December 30, 2009 Posted December 30, 2009 Fry's has a 3PDT switch that could be used to eliminate the relay and diode. Connect the white and gray wires to one set of normally open contacts, and switch the IPOD audio with a pair of normally closed contacts. Frank D. http://www.frys.com/product/2860844#detailed
emtdouggood Posted January 2, 2010 Posted January 2, 2010 but my radio only pics up AM so i might replace all.
warthogcrewchief Posted January 3, 2010 Posted January 3, 2010 I think this should be added to the Tech library.
frankd Posted January 12, 2010 Posted January 12, 2010 I found my notes and they had the pinout of the DIN connector that goes into the cassette deck. If you want to leave the connector on your cable you can purchase an 8 pin DIN female connector from NKCelectronics.com--the stock # is CON-0008. The pin location is for the cassette deck socket and the back side (where you solder the wires) of the connector. If you look into the plug, remember the rotation is reversed. The pins are numbered--verify that you are using the correct pin by looking at the numbers. Frank D.
mbrood Posted January 17, 2010 Posted January 17, 2010 (edited) Does anybody have their radio amp out so we can put to bed the correct pinout for the cassette cable? Pin orientation seems to vary, manufcturer to manufacturer and all we REALLY want to know is what Yamaha used and THAT pinout. Edited February 5, 2010 by mbrood
warthogcrewchief Posted January 18, 2010 Posted January 18, 2010 I have an '89 that has all the plastic removed while I do some rebuilding/repairs. The tape player and AM/FM tuner are sitting in my house, and the amp is sitting on the gas tank - very accessible. What exactly do you need me to look at on my amplifier or the tape deck?
warthogcrewchief Posted February 3, 2010 Posted February 3, 2010 (edited) Does anyone know of a way I can add the MP3 input (while removing the tape deck) that won't require me to permanently modify my bike? I was thinking about getting a female 8-pin connector and then wires from the new connector to make the MP3 input. I'm guessing I use the 8 pin male connector/wire that leads to the smaller blue connector that is attached to the amp control? Anyone have any suggestions as to good places to find these connectors (my first thought was Radio Shack). http://i19.photobucket.com/albums/b160/warthogcrewchief/100_0890.jpg http://i19.photobucket.com/albums/b160/warthogcrewchief/100_0889.jpg http://i19.photobucket.com/albums/b160/warthogcrewchief/100_0888.jpg Edited February 3, 2010 by warthogcrewchief
Freebird Posted February 3, 2010 Posted February 3, 2010 You won't need the 8 pin cable at all. Simply unplug the aux cable from the back of the cassette deck and run it out. It is not part of the 8 pin cable at all.
warthogcrewchief Posted February 3, 2010 Posted February 3, 2010 I must be a little confused. There is only one cable that connects to the cassette deck, which is hardwired via the blue 24-pin connector to the amplifier/intercom control panel. It is the one that is pictured in my previous post. That cable, which has an 8-pin connector, is the one I believe that should have the 3.5 mm female connector (I believe its the standard MP3 input) connected to it. However, I'm not sure which two pins need to be connected to the two wires of the 3.5 mm MP3 input. I've heard that the stereo won't work at all with the tape deck removed. Which pins needs to be jumped to "trick" the stereo into thinking the tape deck is still there. Thanks in advance, WHCC
Freebird Posted February 3, 2010 Posted February 3, 2010 You wouldn't be NEAR so confused if I would pull my head out of the dark place. Very sorry....I neglected to notice that we were talking about a first gen. The fact that it is posted by somebody who clearly states in his post bit that he has a first gen and the fact that it is posted in the first gen tech talk area probably should have been a decent clue but I am plenty capable of ignoring such subtle hints.
warthogcrewchief Posted February 3, 2010 Posted February 3, 2010 I emailed someone the pin orientation of the 8-pin connector that connects to the backside of the tape deck. Here is the orientation looking at the open end of cable plug (I guess it would be considered the "male" end).
