dingy Posted September 16, 2009 #1 Posted September 16, 2009 I started another thread so if any one had downloaded prior versions they would see the update. With help from Ozlander I believe that this is about as good as I can get this schematic. I have added the internal wiring on relays & rectifier. Added coil resistance on relays, generator & ignition coils. Added ignition coil #'s and location on bike. Added bulb p/n's. Cleaned up the wiring in handle bar switch area some more. Overall I have eliminated as many wire crosses as I can. Electrically, this matches what is in the owners manual. I didn't show internal wiring for flasher relay as it is fairly complex, not just a standard flasher. This looks best at 11" x 17" size. Office Max or Staples can print in color at that size for about a dollar. Dingy
Freebird Posted September 16, 2009 #2 Posted September 16, 2009 Great job. I have also copied it to the First Gen Tech Library. Thanks much. How about something like this for the RSV.
