Have you checked the squelch on your CB? If it is set too low, you will pick up transmissions and the radio goes out when that happens. Try setting it all the way up to max on the squelch.
Could this be a problem even if the CB is off?? I have been loosing my XM radio, thought at first it was the power plug, but after watching the radio, its not loosing power, just the sound, only last a few seconds then comes back on..:confused24:
