Goofeychuck Posted September 15, 2009 #1 Posted September 15, 2009 My radio is cutting out badly but I cant find anything wrong any suggestions?
Freebird Posted September 15, 2009 #2 Posted September 15, 2009 Have you checked the squelch on your CB? If it is set too low, you will pick up transmissions and the radio goes out when that happens. Try setting it all the way up to max on the squelch.
Goofeychuck Posted September 15, 2009 Author #3 Posted September 15, 2009 WOW I went out and checked the cb and sure enough on the right chanel they were breaking in. Thanks for the help
Freebird Posted September 15, 2009 #4 Posted September 15, 2009 No problem. I'm glad it was that simple.
Kregerdoodle Posted September 15, 2009 #5 Posted September 15, 2009 Could this be a problem even if the CB is off?? I have been loosing my XM radio, thought at first it was the power plug, but after watching the radio, its not loosing power, just the sound, only last a few seconds then comes back on..
Freebird Posted September 16, 2009 #6 Posted September 16, 2009 No, it wouldn't cause it if the CB was off. XM will lose the signal sometimes if there is heavy tree cover or bluffs alongside the road.
