Sheradan Posted September 8, 2009 Posted September 8, 2009 NO SMART REMARKS!!!!! I don't have the little plastic dip stick for the rearend oil. Can somebody at least give me a measurement off of there's so I can make my own? I would very much appreciate it.
SilvrT Posted September 8, 2009 Posted September 8, 2009 NO SMART REMARKS!!!!! I don't have the little plastic dip stick for the rearend oil. Can somebody at least give me a measurement off of there's so I can make my own? I would very much appreciate it. I don't recall having to use a dipstick on my rearend .... in fact, I don't recall ever having a dipstick for or in my rearend... I think ya check it with any old "rear end dipstick" aka a piece of wood and the level should be about 1 inch down from the top (izzat about right boyz?)
tvking63 Posted September 8, 2009 Posted September 8, 2009 NO SMART REMARKS!!!!! I don't have the little plastic dip stick for the rearend oil. Can somebody at least give me a measurement off of there's so I can make my own? I would very much appreciate it. I have the same issue and was wondering how to check it as well.
Jrichard Posted September 9, 2009 Posted September 9, 2009 NO SMART REMARKS!!!!! I don't have the little plastic dip stick for the rearend oil. Can somebody at least give me a measurement off of there's so I can make my own? I would very much appreciate it. THOSE dipsticks came on the old XS 1100---in the tool kit!!! ya interested???????? -I have one 15$
Venturous Randy Posted September 9, 2009 Posted September 9, 2009 I believe most on here fill it to about the bottom of the threads. I think that is what I did. RandyA
BuddyRich Posted September 9, 2009 Posted September 9, 2009 Every rear end I have ever lubricated I always fill it till it starts to run out. Then put the plug it. Never used a dipstick
skydoc_17 Posted September 9, 2009 Posted September 9, 2009 Because the final drive on BOTH First and Second Gens. is vented just fill the rear end till it starts to "dribble out" and put the plug in. The extra 1/2 oz. of rear end lube will lower the operating temp. of the final drive by 5 degrees (actually tested it). Any extra gear oil will exit the final drive in the form of a mist thru the vent. (see pic below)
Sheradan Posted September 9, 2009 Author Posted September 9, 2009 Thank you all. I'll just fill er up.
SilvrT Posted September 9, 2009 Posted September 9, 2009 Thank you all. I'll just fill er up. Great... can we start with the "smart remarks" now??? ....make sure the vent isn't clogged so that any buildup of gasses can pass from your rearend.
Iowawegian Posted September 9, 2009 Posted September 9, 2009 Thank you all. I'll just fill er up. That's what they all say.
