I have a 96 Royal Star Tour Classic i bought about 6months ago and it has developed a new noise. It sounds like a tire or [ame=http://www.starbikeforums.com/forums/showthread.php?t=873#]belt[/ame] rubbing, but only when I coast or decelerate i in gear with the clutch out. i have read the vast array of threads about "chirping" and "whining" because of the gears and clutch basket, but all these mention the noise in acceleration and not deceleration. i don't have that problem, on when coasting or slowing down. I would greatly appreicate any help or advice.
Thanks,
Sam
p.s. i should note that I have already changed the oil, and the final drive hypoid oil, both with no change to the noise.
Might be the hub pins which are know to squeak..
[ame=http://www.venturerider.org/forum/showthread.php?t=1326]VentureRider.Org[/ame]
Honda Moly60 lube is what most people use on them.
  • 2 years later...
Mine started to do the same thing on the weekend. Went for a ride and on the way home a low tone whine developed when idling. Once the clutch was pulled in or I accelerated the noise went away. What could the problem be?
I am here: [ame=http://maps.google.com/maps?ll=-34.068159,150.798371]Google Maps[/ame]
