Good Morning Everyone,
I would like to replace my stock passing light bulbs with a brighter halogen lamp. However i'm not interested in increasing the amount of wattage draw on the system.
My question is, what lamp would you recommend for this application? I would like a nice wide pattern not a narrow beam. I was told the Silver Star would work, but I dont know which one to look for. I like the super bright white look compared to the yellow tungsten.
Forgot to mention i have the sealed beam type !
Thank you in advance for your suggestions!
Please ride safe
Frank
Edited by frankc
here is a list of some of the acceptial sealed beam PAR36 lamps for motorcyles. Most will not meat your neeeds but are provided for all to view.
7400 are 12 degrees wide by 5 degrees wide at about $19.5
4461 are Trapezoidal degrees wide by degrees wide at about $12.3
4416 are 11 degrees wide by 4 degrees wide at about $12.33
4415 are 40 degrees wide by 5 degrees wide at about $14.13
4411 are Trapezoidal degrees wide by degrees wide at about $7.8
4406 are 80 degrees wide by 30 degrees wide at about $11.94
4405 are 5.5 degrees wide by 5.5 degrees wide at about $7.8
H7600 are 9 degrees wide by 4.5 degrees wide at about $
H7604 are 7 degrees wide by 5 degrees wide at about $
16540 are 10 degrees wide by 10 degrees wide at about $
19873 are 8 degrees wide by 6 degrees wide at about $16.46
19876 are 11 degrees wide by 9 degrees wide at about $16.46
19878 are 6 degrees wide by 4 degrees wide at about $15.56
19879 are 11 degrees wide by 9 degrees wide at about $15.56
22983 are 11 degrees wide by 4 degrees wide at about $12.33
24425 are 6 degrees wide by 5 degrees wide at about $
24506 are 11 degrees wide by 4 degrees wide at about $
42841 are 9 degrees wide by 4.5 degrees wide at about $37.68
43576 are 7 degrees wide by 5 degrees wide at about $21.42
15129 are 7 degrees wide by 4 degrees wide at about $29.19
42838 are 7 degrees wide by 4 degrees wide at about $37.68
39817 are degrees wide by degrees wide at about $
4509 are 7 degrees wide by 7 degrees wide at about $25.8
4631 are 13 degrees wide by 12 degrees wide at about $48.63
4313 are 16 degrees wide by 7 degrees wide at about $23.75
55100 are 5 degrees wide by 5 degrees wide at about $
55090 are 13 degrees wide by 13 degrees wide at about $
55118 are 6 degrees wide by 6 degrees wide at about $
107782 are 12 degrees wide by 12 degrees wide at about $7.53
107784 are 5 degrees wide by 5 degrees wide at about $
107794 are 12 degrees wide by 12 degrees wide at about $7.53
107796 are 5 degrees wide by 5 degrees wide at about $7.53
107788 are 12 degrees wide by 12 degrees wide at about $7.53
107790 are 5 degrees wide by 5 degrees wide at about $7.53
H7616 are 7 degrees wide by 4 degrees wide at about $
There are also some dual fillimat PAR36 lamps on the market but they would be aginst federal law to install as motorycles are only allowed two headlamps, and sense thies have two patterns, they would be classified as a headlmp.
Look for 4440, 4460 H4460 or 4456 lamps in the online catalogs..... but they cost about $30 each........
Edited by KiteSquid
I did not see the Wagner 4449 on the list. This is what I have in mine, I do not have the specs on it offhand but when I picked up my bike there was a Yamaha one in the left spot lamp and the 4449 in the right and I couldn't tell a difference between the two.
I got them for 15 a piece.
Great info though kite! Thanks
