gershum Posted August 30, 2009 Posted August 30, 2009 I need some help! my power outlet has no power i do not know which fuse supplies the power , also need a wiring diagram of this outlet
midnightventure Posted August 30, 2009 Posted August 30, 2009 You can get the service manual here. [ame=http://www.venturerider.org/forum/showthread.php?t=1828]Download the Owners and Service Manuals - VentureRider.Org[/ame] I believe the fuse for it is behind the right lower cowling. It is not fused very high so it is easy to blow.
LilBeaver Posted August 31, 2009 Posted August 31, 2009 You can get the service manual here. Download the Owners and Service Manuals - VentureRider.Org I believe the fuse for it is behind the right lower cowling. It is not fused very high so it is easy to blow. Yup - it is a 5 amp fuse
sgripp Posted August 31, 2009 Posted August 31, 2009 Just changed mine. It is behind the right lower cowling and pretty simple to get at. 7-7 of the manual tells you how to remove the cowling 7-35 give you a description of the fuses
