Sideoftheroad Posted August 28, 2009 #1 Posted August 28, 2009 Can anything be put in between the brackets on each side? This is where it bolts onto the bike w/ the 2 bolts. We will only use the radio antenna side as an example. Using the 2 bolts, can another piece of metal be sandwiched between the bracket that attaches to the antenna and the side that attaches to the bike. What I am wondering is if the metal piece with either affect radio reception or the SWR on the cb. This would be a piece of metal on each side of the bike Hope this makes sense. If not let me know and I will put it together and post pics. Thanks
rod Posted August 28, 2009 #2 Posted August 28, 2009 As long as you have a good ground I would say go for it. Rod
