Black Owl Posted August 21, 2009 #1 Posted August 21, 2009 Okay, who can answer a question about a Mercruiser 454 w/Bravo I drive assembly? Need to know if it is possible to shift from forward to reverse while under load? Thanks much
utadventure Posted August 22, 2009 #2 Posted August 22, 2009 Black Owl- Were you looking for www.iboats.com? Normally, though, you have to go to neutral first to prevent damage to the gears Dave
BOO Posted August 22, 2009 #3 Posted August 22, 2009 Okay, who can answer a question about a Mercruiser 454 w/Bravo I drive assembly? Need to know if it is possible to shift from forward to reverse while under load? Thanks much I think you are talking about a two lever control and I'm pretty sure you can't even get the lever out of gear let along force it into reverse. I think the way the control is made it won't allow things like that to happen. BOO
MiCarl Posted August 22, 2009 #4 Posted August 22, 2009 I think a bravo drive is a single control. In any case, l whether single or dual lever, the control is designed to prevent you from shifting unless the throttle is backed off. You could certainaly defeat the mechanism, but I can't imagine why you'd want to. As a practical matter I believe the dogs are undercut (like on a motorcycle) and will resist disengaging while under power.
dksmith196958 Posted August 22, 2009 #5 Posted August 22, 2009 u will damage the lower unit....if u are just over idle going slow to dock it wont hurt..but goin across the lake u will cause damage to the lower unit and or the transom 454 has a lot of torque...along with going backwards to fast could fill the boat maybe evan sink it.. why would u ask ? ?
wes0778 Posted August 22, 2009 #6 Posted August 22, 2009 you could probably do it ONCE... Don't know how the Mercruiser lower unit works, but YEARS ago the Johnson/Evenrude used magnets and a spring that tightened like a "Chinese handcuff" to shift. There were no "dogs". If that is the case here there would be no problem making the shift. There would however most likely be LOTS of problems after the shift, if it was done much above idle.
